Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Dryer timer knob as well as selection knob on dryer replaced
Hi I would like to know if you can tell me how to go about replacing both of the above referenced knobs??
  • 639 Answers
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
SOURCE:
The timer knob is stripped out
Replace the timer knob...it is cheaper than replacing the dryer.
Go to: partselect.com/
You should be able to find the replacement knob for your timer
Please rate me
Sep 30, 2010 | GE DWSR463EGWW Electric Dryer
I switch the dryer on the light comes on as normal
HI. the filter is fine. Anytime you can hear a buzzing, That is behind the timer module, this will indicate that there is a serious issue concerning the timer mechanism. This device is damaged. The actual timer motor is failing. This will not allow for proper advancement of the cycle selected, in this case. The entire timer control device will need to replaced asap. Once replaced, the unit will operate correctly.
Oct 30, 2009 | Candy CDC266 Dryer
Hi my dry had a broken timer knob and the dryer would work if I pushed the knob I got a replacement part but dont know how to rewire it agen and the part looks different the old one had T80 on it but this...
Your timer switch should come with a wiring diagram.
Check with the supply house you got the timer from and let them make sure you have the right part for your model dryer.
Sometimes the new timer will be different, that is where the wiring diagram comes into play.
I hope this helps
Oct 01, 2009 | Fisher and Paykel Dryers
Whirlpool Ultimate Care II Dryer timer knob
The timer cam is not aligning the internal switches. Replacing it is the only fix.
Eric
Sep 17, 2009 | Kenmore 62602 Electric Dryer
Maytag Atlantis Dryer pull-knob won't start dryer
sad!! To Say!! It's a bad Timer!!
Maytag went cheap on there Timers!!!!!!!!!!!
I Work on them and have been in a few homes and had to replace them even less then a year old!!!!!!!!!!!!!
Sep 13, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Kenmore Electric Dryer 66812 clicking not starting
I hate to tell you this, but it is probably the timer. The good news is that it is easy to replace and you don't have to have a tech to do it.
Jan 05, 2009 | Kenmore 659 Electric Dryer
Kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
Aug 29, 2008 | Kenmore 60172 Electric Commercial Dryer
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
57 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
