Question about Kenmore 24032\24036 Top Load Washer
Kemore 92274100 washer
Tubb wobbles durning spin cycle. New springs, bearings tight. Unsure were to rehook the counterweight spring.
    Genius:
  • 1,028 Answers
Counter weight spring hooks in hole left side of rear spring bracket thens hooks through directly below that in base..unless hole is rusted out then just drill a new one ..by the way some wobble is normal a stationary tub would cause a lot more vibration
Posted on Aug 20, 2008
Loud in spin cycle/throws oil
If the pulley wobbles, it sounds like a bad bearing, and that could account for the oil/grease. One more thing you might check, mine acted bad in the spin cycle, but mine was the leveling spring at the bottom of the drum. The way to tell from the top is if the drum tends to lean forward instead of being centered when sitting. Good luck.
Jan 08, 2018 | Maytag MAH55FLB Front Load Washer
Durning the spin cycle, the washer is jumping all over the place
One or more of the suspension springs have failed. Here is a link to the spring.
Take a look at this video.
Oct 15, 2012 | Whirlpool ATW4475VQ Washer
Btd 140 rfe chuck not spinning true
The usual reason for major wobble of the spindle is a worn gearcase. It can easly be replaced. Any good repair agent can do it. If you want to do it yourself. Simply remove the circlip holding the chuck sleve on then take off the washer, spring and balls. release the light unit from underneath and take off the locking block. The gearbox cover will then unscrew (but can be tight) I think it is lefthand thread.Check spindle for wear and lubricate the bush bearing in the new gearcase, then rebuild in reverse mode
Jun 17, 2012 | Makita 18V LXT Lithium - Ion Cordless...
Washer is shaking while spining
Just from what you stated .If your cloaths are unbalanced it will wobble while in spin cycle,if its not unbalanced, Probily a broken spring,these units use 3-4 springs ,on the wash drum ,to keep them stable while in the spin cycle.
Feb 10, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Whirlpool duet mod#ghw9160pwo washer shakes the whole house during spin cycle. shocks look good, springs look good and adjustable feet are tight and on floor. the washer is level and i get no alarm...
Unit probably has bad main shaft and bearings. Worn bearings will cause excessive shaking on spin cycle. The shaft, bearings and seal will have to be replaced. Also if you grab the tub by the top and shake it up and down, it will have a little play in it. That will confirm bad tub shaft bearings. It's a pretty big job for a DIY.
Dec 10, 2017 | Whirlpool Washing Machines
Getting dc and uc codes. Took clutch apart and cleaned and checked spring as suggested. Everything in there is ok. I don't have an upper bearing just the 1 way bearing. There is a lot of wobble in the spin...
Is the wash tub rotating CW in the wash cycle (tumblers should rotate only)? You can release the washer top to observe. If so I feel there may be binding in what I call the Spinner support bearings you can see those at the end of my Clutch Fix post.
Are you taking dc/uc unballance error codes while in wash cycle or just during spin cycle?
I believe somewhere around series 12 and above the machine design went to the integrated lower tub bearing/One-Way roller clutch bearing.
Any sign of wash water contaminating the Clutch Pulley One-Way bearing (rust)?.........Rich
Oct 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore washer wobble, banging
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24902200&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Apr 18, 2010 | Kenmore Washing Machines
Have a 110.92380200 top load washing machine. replaced 3 suspension springs and 1 counterweight spring. not sure where the counterweight spring goes? I do know one side hooks to the rear bracket on which...
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The sections on machine base or tub should give you a decent diagram of where the springs go.
Sep 09, 2009 | Kenmore Washing Machines
Washer leaks during spin cycle
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
May 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Mar 02, 2009 | GE WJSE3110A Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
350 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
