Question about Asko Washing Machines
Fault code f3 on asko wm 200 washing machine - Asko Washing Machines
  • Anonymous Aug 26, 2008
    F3 on my Asko F3 and is won't pump out the rest of the water. I had to go in manually and pull the little metal ripcord at the bottom left side of the machine behind the little metal door.
  • 351 Answers
Blockage in pump or the drain hose sink end if it under the sink
Posted on Aug 27, 2008
F3 Error Message
F3 is a pump problem check the pump trap and clean it this should clear it up...
Aug 25, 2007 | Asko W6441 Front Load Washer
Washing machine wont drain, door is locked, and cant get clothes out of machine, says F1 and F3 error. wat do i do?
sounds like a safety check is on. check the pump to make sure nothing is stuck in there. read the manual for checking pump on that Asko machine..
Oct 14, 2009 | Asko W6021 Front Load Washer
The washing machine stopped on the rinse (6) with an F-3. Now what do I do?
"F3" on Asko means the machine detected an interuption in the drain sequence. could be as simple as a coin or some other debris causing the fault, but it may be the pump is faulty as well. first things first.
**UNPLUG the unit from the dryer, or from the wall, which ever applies to your set-up**
in the lower left corner on the front of your washer is a "pin catcher/lint filter" for the pump (a pump insert asko calls it). unscrew this insert, clean out whatever is obstructing the pump and you should be fine to continue. unless the pump itself is at fault. **you will need to drain whatever water is in the unit into a drain, or pan thru the little drain line from the pump (refer to your manual if you have access to it).
hope that helps,
good luck
Sep 28, 2009 | Asko W6021 Front Load Washer
Not only is my asko washing machine leaking, the code "F3" flashes continuously, and my clothes are locked inside. What does "F3" mean? and how do I get the door to unlock?
F3 is a blocked coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Hope it helps if NOT let me know more about your problem... and I will help
Jun 30, 2009 | Asko W6441 Front Load Washer
My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models If the coin trap in the drain is clear of debris, try this. Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Just ran the machine now and fault cleared.
Good luck
Jun 15, 2009 | Asko W6461 Front Load Washer
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
We have a code F3 on our asko washing machine
Most likely a drain pump problem. Make sure there is nothing in the drain hose. Then it would be a bad drain pump
Jun 09, 2008 | Asko Washing Machines
F3 Error Message
The F3 error code relates to a pump problem Check pump trap and clean. Good luck!
Washing Machines Logo
228 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
