Question about Texas Instruments TI-15 Explorer Calculator
Multiples On the old math explorers we could get multiples just by entering  + (a number) = =  = = = like + 6 = and get 6, 12, 18, 24, 36...... On the TI15, we can't figure out how to do this.  We really need to be able to get lists of multiples for our new math program. We just purchased 100 of the calculators for our fifth grades, so any help would be appreciated.
  • Texas Instru... Master
  • 7,993 Answers
You can still that on the TI 15 explorer (look for constant calculations page 57 in your user manual or maybe the teacher's guide that you can download from education.ti.com)
1. First you define the operation you want to perform, using the OP1 key as follows
[OP1] [+] [6] [OP1] this sequence stores the operation you intend tu use repeatedly.
2. Since you want multiples you must start the sequence with 0
You do that by keying in the number 0
3. Press [OP1] repeatedly.
Each time you press [OP1] a counter shown on the lower left corner of the screen increases its value by 1, and the result (on the lower right corner) shows you the next multiple.
If you just want to add the same number repeatedly starting from some chosen number, in step 2 above use any number but zero.
[OP1] [+] [6] [OP1]
[OP1] [OP1] [OP1 etc.
will generate the numbers 2+6=8, 14, 20 etc.
Hope it helps
Posted on Aug 20, 2009
How do I enter a mixed number?
Use the fraction key [a b/c]
7 5/9 is entered as 7 [a b/c] 5 [a b/c] 9 [=/ ENTER/ EXE]
Sep 30, 2014 | Texas Instruments TI-15 Explorer...
MATH WITH DIVISION
Both numbers are multiple of 100 (the two zeros at the end). Divide both numbers by 100 (remove two zeros from each). You are left with 20/6. Now divide each number by 2 to get 10/3. Use the technique you learned to calculate the result.
Feb 06, 2014 | The Learning Company Achieve! Math &...
In casio fx-991ES, i am able not to get the matrix multiplication as well as inverse when i do so get math error.
This post is rather exhaustive as regards the matrix capabilities of the calculator. So if the post recalls things you already know, please skip them. Matrix multiplication is at the end.
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matrices, at the end.)
First you must set Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
[2:Data] enter values in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
To add matrices MatA+MatB (MUST have identical dimensions same m and same n, m and n do not have to be the same)
To subtract MatA-MatB. (MUST have identical dimensions, see above)
To multiply MatAxMatB (See below for conditions on dimensions)
To raise a matrix to a power 2 [x2], cube [x3]
To obtain inverse of a SQUARE MatA already defined MatA[x-1]. The key [x-1] is the x to the power -1 key. If the determinant of a matrix is zero, the matrix is singular and its inverse does not exit.
Dimensions of matrices involved in operations must match. Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular numbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrix by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Thus, to be able to multiply a kXl matrix by am mXn matrix, the number of columns of the first (l) must be equal to the number of rows of the second (m).
So MatA(kXl) * MatB(mXn) is possible only if l=m
MatA(kX3) * Mat(3Xn) is possible and meaningful, but
Mat(kX3) * Mat(nX3) may not be possible.
To get back to your calculation, make sure that the number of columns of the first matrix is equal to the number of rows of the second. If this condition is not satisfied, the calculator returns a dimension error. The order of the matrices in the multiplication is, shall we say, vital.
Dec 18, 2010 | Casio FX-115ES Scientific Calculator
How do you put in a fraction to mulitiply it by another fraction?
A fraction is just a particular number.
  1. Enter numerator of first fraction
  2. Press the division sign
  3. Enter the denominator of first fraction
  4. Press the multiplication key
  5. Enter second numerator
  6. Press the division key
  7. Enter the denominator of second fraction
  8. If you want a decimal result press [ENTER]
  9. However, if you want a fraction press [MATH][1:
Sep 21, 2010 | Texas Instruments TI-83 Plus Calculator
I have a very strange math teacher that collects old math books.One day i asked him how many old math books he has.Being a math teacher, he responded, "if i divide the books into two unequal whole...
Your teacher has 64 old math books.
Define the variables:
n = the total number of books x + y = the number of books divided into two groups (x being one set of books and y the other)
Equation set-up from the problem:
64(x - y) = x^2 - y^2
Work it out:
64(x - y) = (x + y)(x - y)
64(x - y) = (x + y)(x - y) (x - y) (x - y)
64 = (x + y)
Therefore, 64 = n
Sep 18, 2010 | Computers & Internet
UNDERSTANDING MATH PROPERTIES OF REAL NUMBERS
Hii,here is list of basic real numbers properties applying them you can solve the problems easily.
Assuming a,b,c,d are real numbers:
1)Commutative Property
a) Property of Addition: a+b = b+a
b)Property of Multiplication: ab = ba
2)Associative Property
a)Property of Addition: (a+b) + c = a + (b + c)
b)Property of Multiplication: ( ab )c = a ( bc )
3)Additive Identity:
a+0 = a where 0 is the additive identity
4)Additive Inverse:
For real number a, there exists -a such that
a+(-a) = 0
5)Multiplicative Identity:
For real number a,
1 X a = a
where 1 is the multiplicative identity
6)Multiplicative Inverse:
For real number X where a≠0, there exists 1/asuch that
a X(1/a) = 1
7)Zero Product Law:
If ab = 0, then a=0 or b=0 or both a and b = 0.
8)Distributive Properties:
a)Left distributive law
a (b + c ) = ab + ac
b)Right distributive law
(a + b) c = ac+ bc
Jun 09, 2010 | Vivendi Excel@ Mathematics Study Skills...
How do i do fractions with this calculator? there are so many keys i dont know what to push.
The primary key to enter something that resembles a fraction is the division key, the one above the multiplication key.
However, any division you enter yields a decimal number, unless the result is an integer.
To keep the result of a division as a (reduced) fraction use the [|=>Frac] or [ToFrac] command. It is accessible by the following key sequence
[MATH][1:ToFrac].
Insert it after the fraction, before pressing the [ENTER] key to get the result.
By pressing [MATH][2:ToDec] you convert a fraction in to a decimal number.
Apr 10, 2010 | Texas Instruments TI-83 Plus Calculator
I can't find this button on my calculator / this
A fraction is in fact a ratio of two number: a division of a numerator by a denominator. The key used for the division operation is the one above the multiplication sign and below the caret [^], and in thee rightmost column of keys.
Beware that this calculator converts any ratio of two numbers into a decimal value. To keep a fraction in a fraction form you must use the [|=>Frac] or [ToFrac] command. To convert a decimal result to a fraction, use the [|=>Dec] command.
These commands are accessible through the CATALOG or more easily by pressing [MATH] (under the ALPHA key) and selecting [1:|=>Frac], or [2:|=>Dec]
Ex: to keep 27/48 in fraction form you enter
27 [/] 48 [MATH][1:|=>Frac] [ENTER]. Result is 9/16
You will notice that the resulting fraction is reduced to its simplest form.
To convert the above result from fraction to decimal press [MATH][2:|=>Dec]
A fraction can always be approximated by a decimal value but the converse is not always possible.
Jan 23, 2010 | Texas Instruments TI-84 Plus Calculator
Intergers
There is no such button, but there is a command accsssible as follows
[MATH] right arrow to highlight [NUM] and 5:int( [ENTER] In short
[MATH][NUM][5][ENTER]
The command appears on home screen, where you give it the decimal number whose inter part you want.
Ex; int(15.87) gives 15
You shoul explore the catalog of all commands avaible on your calculator. You press [2nd][CATALOG] (under the digit 0) and scroll down or up. If you know the command, while in [catalog] press [ALPHA] and enter the first letter of the command. The cursor moves to the first occurrence of the letter and you can then scroll more to reach the command.
Hope it helps
Jun 04, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-15 Explorer Calculator Logo
159 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
