When printing my pictures at home the color does not appear as it does in the preview picture. The tones are off. I cleaned the printhead. It doesn't appear to be producing any of the blue tones.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
That's an issue with color balancing. not too easy, frankly. what kind of printer and computer you using?
Posted on Aug 19, 2008
The printed picture is not good. There is a pink tone to it. I have changed the colour and black cartridges but not much of an improvement. I use Kodak photo paper.
My first guess would have been low ink for cyan and yellow, but you said you have changed the cartridges. You may want to run a cleaning cycle a few in case there was cross contamination in the printhead making the colors look wrong. To perform a printhead cleaning hold down the Cancel and Copy/Resume buttons until the On/Off light flashes. Then release the buttons and the printer will run a cleaning process. Hold down Quantity and Cancel until the On/Off light blinks to print a test page. The printed test page should look like this:
http://www.kodak.com/global/images/en/service/printers/aio/troubleshooting/ESP_Test_Color_Block.jpg
If it matches these colors, then the printer is not the problem. Otherwise, you may have to replace the printhead, if you have had your printer for a while.
I hope this helps! Good luck!
Feb 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My pictures are all printing with a purple look, such as water, clothes, sky, etc... There is no other color hue, besides purple in the picture.
Issue on kodak AiO printer not printing correctly you need to contact kodak support line at 1 800 421 6699 for printhead replacement.
Step that you can try
1. Clean Printhead twice press Copy button and Cancel button at the same time for atleast 10sec or until the printer move. Note cleaning printhead will consume your ink.
2. Reseat Printhead open the printer access door remove the ink cartridges and the printhead then close the printer access door wait until red light flash on the printer open the printer access door insert back the printhead then ink cartridges
3. Replace printhead contact kodak support
Nov 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
The preview colors do not match the actual print.
This is usually a cartridge issue. If that doesn't work, then try cleaning the printer head. Make sure that there is paper in the input tray. On the product control panel display, touch the tools icon. Touch Tools and then touch Clean Printhead . The product calibrates, cleans, and aligns the printhead and then prints a test page. If this doesn't work, please visit this site: http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=33721&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3315742&lang=en
Nov 08, 2009 | Televison & Video
Certain color parts previewed on computer don't print out
Depending on the software you are using to do the preview...( a word processor, photo software ..etc) the preview is just that...it simply lets you look at the document or picture to see that you have formated it correctly in the main program. You should not try to print from the preview...what you can do is exit the preview function and return to the main software. the go to the file menu and exicute the print command and or do the page setup for the picture or document.
May 31, 2009 | Office Equipment & Supplies
COLOR TONE LINES IN PICTURE
You have a bad printhead. It is a known defect and Kodak will send you a new printhead.
Jan 18, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Poor picture printing
Do not try to clean print head again and again, it consumes too much of ink.
Try reseting print head and then calibrate it.   after then check nozzles and align prinhead.   Now u can try cleaning printhead last time.
If it does not fix your issue , your printer needs to be replaced  (In case printhead has already replaced within 30 days)
MS
Dec 22, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a Kodak easyshare all in one printer 5100
You need to clean the printhead of the printer to solve that
issue. Because everytime you print, excessive inks are going
to the printhead that's the reason why it's clogging the
system up. That's because Kodak printers is using
"pigments" as inks that's why Kodak printers are producing
high quality prints unlike other printers - a photo printed from
kodak could actually last for about 100 years. Now back to
your issue, you need to clean the printhead from the printer
but not manually. You could clean it by going to the
software of the printer namely the KODAK HOME
CENTER SOFTWARE. You need to click the "?" mark
icon on the upper right corner of the software window then
under the General Links select Maintenance then choose
Clean Printhead. Do it at least twice and then try making
prints. If that still doesn't work try calling Kodak Technical
Support Representative: 1-800-421-6699
I hope I have been some of help. ^_^
Nov 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak Easyshare 5300 All-in-one Inkjet Printer
Hello ocalvin,
You need to clean the printhead of the printer to solve that issue. Because everytime you print, excessive inks are going to the printhead that's the reason why it's clogging the system up. That's because Kodak printers is using "pigments" as inks that's why Kodak printers are producing high quality prints unlike other printers - a photo printed from kodak could actually last for about 100 years. Now back to your issue, you need to clean the printhead from the printer but not manually. You could clean it by going to the software of the printer namely the KODAK HOME CENTER SOFTWARE. You need to click the "?" mark icon on the upper right corner of the software window then under the General Links select Maintenance then choose Clean Printhead. Do it at least twice and then try making prints. If that still doesn't work try calling Kodak Technical Support Representative: 1-800-421-6699
Nov 06, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Color is all wrong
Your pictures are coming out with a blue tint. Remove the color catridge and look at the bottom of it. the Yellow is probably green. If it isn't, trying performing a printhead cleaning through your home center. After that, calibrate the printer, you may see that on the calibration sheet, that colors are missing. Scan the calibration page and then try your printing your pictures. If that doesn't work, contact kodak tech support, you need a new printhead.
Sep 03, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 printer
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
115 people viewed this question
jasbo
jasbo
