Question about Aiptek Cameras
My camera's power turns on then turns off about 5 seconds later. I have tried the battery but even at full charge it still turns off.
  • 790 Answers
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Posted on Aug 19, 2008
My w1 cherry mobile doesn't turned on even the battery is full
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 12, 2012 | Cell Phones
Camera not working even though charged
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge. This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the camera may have a problem that requires professional repair.
Dec 31, 2009 | Kodak EasyShare C513 Digital Camera
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Nikon D90 Memory Card Access Blinking
It's a deadly common problem of D90. Fixation:Simply go to the DSLR repair shop and ask them to change the power circuit board of the camera. Will take $60-70 if the board available. Reason of issue:The power control IC get short and feedback the battery power to the battery causing the draining out and other problem like the top LCD back lamp turned ON after turning on the camera. Careful:To avoid this issue in future, after full charge of the battery, do not put it in the camera right then. Wait for the battery to cool down for 5-10 min and then put it in. With the full charge, the battery hold high ampere for a short time. It could damage the power distributor IC suddenly if you put it in the camera right after a full charge. Best, Leo>>from personal experience<<
Jun 14, 2009 | Nikon D90 Digital Camera with 18-105mm...
My camera went dead, with new batteries...
The MPVR uses a rechargeable Li-Ion battery. It sounds lilke you've got a different model. It's hard to make any suggestions without knowing which camera you've got.
Nov 15, 2007 | Aiptek MPVR Digital Camera
Camera Wont turn on and blue light flashes
The possible answer is that batteries are past thier best now and even a 'full' charge is not delivering enough power. treat your self to new batteries.
Aug 13, 2007 | HP Photosmart M425 Digital Camera
Pentax Optio SV tunrs off immediately
I have the same problem with my camera and the following activities solved it. Remove batteries and clean contacts of battery's host (include cover). Check as well that contacts are not bended and didn't lost their springiness. Good luck !
Aug 06, 2007 | Pentax Optio SV Digital Camera
Screen says battery is full, but wont turn on
I read somewhere that even with a functional lyra, when it displays "battery full", you should keep charging for another hour. This is said to extend battery life and give you an extra 2-3 hours of power. Either this is perfectly normal, or it indicates that the battery reading tends to be inaccurate. In any case, try leaving it charging even after it gives you the message. Another thing to consider is, how long has it been in the box? I'm not sure about lithiums, but most rechargeables I know live longer when used. Live it alone for too long and you shorten it's life. Could be good to get a second opinion on this battery thing though. If there's a warranty, don't let it waste. Good luck
Jun 20, 2006 | RCA Lyra RD2840 MP3 Player
Cameras Logo
229 people viewed this question
Top Aiptek Cameras Experts
mohamed salim shaikh
Greg Cann
Greg Cann
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
