I have an old canon NP2120 Copier. I am getting an error code E000 when I turn it on. Is that something i can fix?
  • sidmjr Aug 20, 2008
    What awesome advice. I will take it apart tomorrow. Do the claws and oil roller have different names? I can't find them @ precisionroller.com. Thanks a lot!
  • doug4526 Mar 28, 2009
    I had the same problem, made the above repair, and now I get a continual jam at the fuser roller. Any suggestions on what adjustment I need to make?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Are you mechanically inclined????
If yes the problem is most likely the fuser lamps are burned out.
This is to take out the fuser unit (the two heat rollers where the paper exits---------let machine cool first!!!!!!!!!!)
1-unplug machine
2-open left side door
3 open front door
4- remove the green knob on the left
5-remove the left side cover ( i beleive you need to take off the two screws on top that hold the glass also)
6-remove the back cover(it is hooked onto the side cover)
7-after removing the side cover look at the fuser left top corner unplug the connector- there should be one on the right also big black wires with a white connector remove the screws that hold the fuser in place
8- once the unit is out there is a lamp that runs the whole lenght of the roller that is the fuser lamp there are wires on each side, remove the lamp bracket holder and one wire, you should be able to tell if it is blown, it will be black and smoky looking not clear.
if you go through these steps you should take advantage and replace the thermistor, thermofuse, claws, and oil roller.
I use to love the 2120 they are one of the best machines Canon put out a true workhorse, do these things and don't worry about hte fuser for another 3-5 years .
If you don't have a parts supplier try precisionroller.com
Posted on Aug 19, 2008
  • CheckitRight
    CheckitRight Aug 20, 2008
    I didn't see it either, but give them a call they can get it for you,
SOURCE:
Canon IR1510 error E000
there is a problem in the fixing assembly something to do with the thermoswitch if i am not mistaken without the full error code it is hard to say exactly what is wrong with it
Jun 10, 2010 | Canon imageRUNNER 2000 Copier
System error E000
The problem discription is very long to be shared here, basically what you have to do is reset the copier
E000
The error history indicates any of the following error codes 4 times: E001,
E002, E003.
Action 1) Clear the error.
Execute '#4 PRINTER RESET" under '#7 PRINTER' in service mode to clear
the error.; then, turn back on the power.
It might be a good idea to get a service manual to get a good insite, here is the link for it;
http://www.techmanualarchives.com/canon-ir1630_1670-service-amp-parts--manual-25159.html
Feb 22, 2010 | Canon ImageRUNNER 1670F Copier
Error code E000
can u please check the fixing
Aug 03, 2009 | Canon imageRUNNER 2270 Copier
Error E000 on Canon copier NP-4540
check the light maybe short. if it is not check the thermostat
Jun 24, 2009 | Canon Office Equipment & Supplies
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
ERROR CODE E000-0320
A E000-0320 code is a fixing unit error code. It is either not warming up or it is getting to hot. It is a thermister is shortting out or a thermal fuse or one of the heating lamps are blown.
Apr 14, 2008 | Canon CLC 4000 Copier
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
Open Questions:
124 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
