Question about Durabrand Anti-Skip CD-895 Personal CD Player
HM3817dt Hi. On the model listed above, the CD pops off as soon as I snap it in place.
  • idahoean208 Sep 23, 2008
    Thank you. I thought that silver disk was a part og the player.
    Mike
I just bought the unit last night and had the same problem. You need to take out the cardboard that's currently inserted as part of the new packaging. That should solve your problem.
Posted on Sep 22, 2008
Philips portable dvd player (white tab or) wire strip is out
This is a really easy fix. There should be a little black bar that is right about the point that the white tab looks like it should go. The black bar will snap into place or pop up if yours is already snapped down. I took the entire DVD player casing off to re-attach this tab but it could probably be done without that in retrospect. I needed the room to maneuver however. The blue tip will insert just below that black bar and when you've met resistance (which will be rather soon, I could see all of the other color stripes) snap the black bar down. The tab should be held in place and the DVD should read again. Hope that helps!
May 01, 2012 | Philips PD700 7 in. Portable DVD Player
Key fell off completely
Set aside the key and retainer that have fallen off. If you lost the key, retainer, or both, you will have to order a replacement from the computer's manufacturer. As an alternate, you may be able to get a replacement from someone who has a non-working laptop of the same model as your own.Carefully pop off another key from your laptop. Choose one that you don't use frequently, and remove it with care so its retainer stays in the proper place. You will be using it as a model for your repair.
Note how the exposed retainer is connected to the keyboard. It will probably be connected at four separate points. This may vary, based on the make and model of your specific laptop. Study it until you feel confident replacing the retainer in the correct manner. Replace the retainer that popped off your laptop. Once you have it secured in place, pop the missing key onto it. The key should snap firmly into place onto the retainer. Replace the key cap on the retainer that you used as your model. Like the other key, it should snap firmly into place, and both keys should now be ready for use.
Mar 22, 2011 | Computers & Internet
HOW DO I UPDATE THE 1412
To update your magellan roadmate is very simple. But take note, there are two (2) types of updates:
  1. Software update, which are free.
  2. Maps update, but you have to purchase them.
Either ways you will get both updates from the support link from th magellan website. For software update:
  1. first go to the website, www.magellangps.com,
  2. Place the cursor on the support link and a list will pop out,
  3. From the list select manuals and softwares,
  4. Select the manuals and software link that is on the page,
  5. You select the vehicle navigation form the list,
  6. Once you select the type some other pages come up then you select the road mate,
  7. Once you select the road mate, a list comes up, then you select the road mate 1412,
  8. Then the download link will pop up, then you click on the link to download it.
  9. Once you download it, connect your gps to the computer, then you update it from there.
Sometimes, the moment you have the magellan roadmate software on your computer, as soon as there is a latest update, it will notify you to download it for your gps update.
To update a map,
  1. You purchase the maps once they are available from magellan website,
  2. go to the website as stated above,
  3. place the cursor on the maps ans a list will come out,
  4. Select either vehicle navigation maps or outdoor maps depending on what you want to update,
  5. Then you select the product type and the product model
  6. A page will pop up with the latest map for you to download.
  7. Then you add to cart.
That way your maps will be updated.
I hope this information helped.
Dec 23, 2010 | Magellan RoadMate 1412 Car GPS Receiver
Call for service error 7410:0112053 on Kyocera FS3900 DN
most likely the drum popped out.
open the left side cover and remove the waste toner bottle..seated just above the waste toner bottle..press on the drum unit that sits above it..you will here it pop back into place .. if you hear it snap back it simply power off than back on printer....
if the drum is seated correctly.. than you need to replace the drum unit
Jan 12, 2010 | Kyocera FS-2000D Laser Printer
How do you remove a radio from a 2007 Tuscson city
Don't know the 'City' model... but if it's anything like the REGULAR Tucson, remove the shifter knob (remove access place to two phillips screws - remove screws). Remove shifter knob. Pop out shifter cover plate (snaps in and out). Remove approx 6 phillips head screws holding the metal plate above the shifter pedistal. Pop out the cosmetic cover around the radio, AC control panel and vents (wire harness connectors to digital clock, fog lamps and emergency flashers (and pass airbag light). You now have access to the phillips screws securing the audio/radio unit.
Oct 31, 2009 | 2007 Hyundai Tucson Limited
How to change interior lite bulb, not sure how to remove cover
Hi, Most covers just snap in place. If there are no screws visible, try popping the cover with aa flat blade. If you need more assistence, get me the model # so I can look your model up.
Thanks
Vic
Jul 18, 2009 | Refrigerators
I am having trouble figuring out how to snap my saftey 1st
Discontinue use at once! Safety First is not on the list of carseats that this model supports, according to the chart in the instruction manual.
Jul 15, 2009 | Baby Trend Snap N Go 1308 Stroller Frame
Broken key.
hi notesticky i once had a problem simlar to this one i was replacing a keyboard to laptop when a key pop-out what i did was to snap back key in place, on the keyboard layout has rigids that snap each key in place but if it's broken you might have to replace keyboard section. you can find a replace keyboard at ebay.com and don't forget put model # maker of laptop. good luck.
May 16, 2009 | Sony VAIO VGN-NS110E/L Notebook PC
HM3817dt
You will not believe it, but he solution if Homer D'OH! simple. Had the same thing, until I realized that what I thought was the CD hold spindle is acually a cardboard protector for the CD components. It seems to be a very flexible CD player "face" correct? It's actually removable cardboard - pull it out and the CD components are now exposed. The CD will properly mount on the spindle...has pretty good sound.
Feb 19, 2009 | GPX HM3817DT Shelf System
Slider popped out
Unless part of the plastic slide has broken off, you can simply "snap" it back in place. Being careful you my need to use a little force but it should just snap back into the track.
Dec 28, 2007 | Samsung SGH-D600 Cellular Phone
60 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
