Question about Aiptek Cameras
My camera tirns on then turns off about 5 seconds later.
  • medleyjohn11 Aug 19, 2008
    sorry, but it didn't do much but after a few times the volume stopped working but I stopped for a minute then when I turned it on again the volume turnned on again but after a couple on seconds it turned back off
  • 790 Answers
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Posted on Aug 19, 2008
Is it worth paying sony to replace lens block assembly on dsc-w5, 6yrs old, or buy a new camera?When I tirn on camera message says turn on & off again, which I do but does not help. Lens moves back...
Replacement of the lens will cost more than the camera is worth. Try these solutions at the following website before deciding to buy a new camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 23, 2011 | Sony Cyber-Shot DSC-W5 Digital Camera
2006 Pontiac sv6 Montana - stalls while driving & will start up once after you pull over and tirn off ignition, but will still do it again...!!! Please help
sound like you have a fuel pump in need of replacement, when you first turn on the vehicle the fuel pump has full pulse.3 minutes later its now at a shorter pulse width they design this in such a way that it can last longer,but as all thing wears out
May 09, 2011 | Pontiac Montana SV6 Cars & Trucks
My canon g9 lens will only come out quarter the way turn on and then go back in and tirn off. It is over 2 years old.
check your battery for full charge, pull out the battery and ckeck if theres moisture keep camera in a dry warm place for some time;
keep camera without sd card and battery for sometime.
all should be well
Aug 15, 2010 | Canon PowerShot G9 Digital Camera
Tv won't turn on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
if it is 2,2 I have start to finish instructions for this repair in this model.
SD TECH
May 01, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Camera screen is white.
E-mail your question to Kodak at: http://www.kodak.com/global/en/service/contactKodak/email/consumerDigital_contact.jhtml?pq-path=13452
Jan 06, 2010 | Kodak V803 Digital Camera
My camera turn right off when i tirn it on
suspect battery is low.
suspect battery has not charged properly in charger.
suspect battery may be defective.
suspect camera is defective.
i would ask a specialist at a camera store to check this.
Nov 15, 2009 | Sanyo VPC-S1080 Digital Camera
My camera's power turns on then turns off about 5 seconds later. I have tried the battery but even at full charge it still turns off.
Hello!!
Regards
Smilemaker.
Aug 19, 2008 | Aiptek Cameras
My camera went dead, with new batteries...
The MPVR uses a rechargeable Li-Ion battery. It sounds lilke you've got a different model. It's hard to make any suggestions without knowing which camera you've got.
Nov 15, 2007 | Aiptek MPVR Digital Camera
Need Help!!!!
Return to seller for replacement under warranty
Apr 07, 2007 | Nikon Coolpix 5600 Digital Camera
Cameras Logo
Top Aiptek Cameras Experts
mohamed salim shaikh
Are you an Aiptek Camera Expert? Answer questions, earn points and help others
