Question about Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh 2022sp internal tray 1
We can't figure out how to fix our copier/fax. it states: " remove paper from internal tray 1"..yet we see no paper, restarting does no help. how do we access internal paper tray 1
  • 3 more comments
  • Allan Aug 26, 2008
    I have the same problem.
    the internal tray is the tray that the paper comes out onto, and there is nothing there.
  • Anonymous Feb 11, 2009
    tengo un problema con ua ricoh 2020 me sale el codigo de averia sc551 soy tecnico y asi que me puedes explicar brevemente
  • Anonymous Mar 12, 2014
    how to select paper tray output on Ricoh 2018D
  • Anonymous Mar 18, 2014
    after cleaning internal parts
  • 4 Answers
Where the paper comes out there is a little black thing that is supposed to stick out. Somebody has pushed it in.
Posted on Sep 01, 2008
  • taps41 Aug 04, 2010
    Found it, who would have thought that something like could cause the whole machine to have a heart attack.....
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Open the door on the front, and it's either the bottom one or just above that..they are marked
Posted on Aug 19, 2008
HP Color Laserjet CP2025n Load Paper
In XP, go to settings; control panel; printers& faxes; then left click your printer and select "Properties". Click the "Device Settings" tab and you should be able to figure it out from there, by clicking the trays and selecting "not available". I have that same printer and I just did it with mine so I know it can be done.
Jun 08, 2012 | HP Laserjet Cp2025n Printer
I have a ricoh fw830 copier with a paper jamb symbol error, where are the sensors to clean?
Open all possible covers and trays from all sides and try to find some tiny bit of paper with your eyes and hands (it could be well hidden). First of all these places:
1) Paper tray/cassette, especially place where the paper gets pulled inside the system. 2) Under the toner cartridge. 3) Duplexer 4) Try to figure out the complete way which paper moves from the paper tray till it comes out.
If every paper seems to be removed, just try to turn off the power, then turn it on again.
Unfortunately there is no manual available digitally as the printer is quite old.
Mar 05, 2011 | Ricoh FW 780 Black and White Copier
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
I have a ricoh aficio 220 and it says internal tray 1 is full remove the copy on the display
There is a sensor above the tray where the paper comes out, and that sensor has a long black actuator. Sometimes that actuator gets turned to the side, and this will cause that message to appear.
Reach above the rollers where the paper exits the copier, find the black actuator, and turn it so that it is hanging down over the tray. Once the sensor is reset that message should disappear.
May 04, 2010 | Ricoh Aficio 220 Laser Printer
Describe your ricoh aficio 2232c manual copier internal tray problem solving Problem display screen says internal tray open cholland@shawu.edu
just take a air blower and flow the area from where the paper comes out ur internal paper tray sensor is dirty
Jan 22, 2010 | Ricoh Aficio 2232C Color Copier
The 2022SP gives me a jam indication but there is no paper jammed.
If it shows it all the time there is paper or at least something, if it jams on the first copy paper size or paper direction issue. Does the display show the paper size and direction correctly? All drawers fail? May have torn paper behind the cover that the bypass tray sits on. -Carl
Jul 08, 2009 | Ricoh Office Equipment & Supplies
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh 3900 L Fax Machine - Bottom Catch Trays (for receiving faxes)
Here the numbers.
H545 2130 Copy Tray 1
H545 2131 Copy Tray Extension
Apr 30, 2008 | Ricoh FAX3900L Plain Paper Laser
Ricoh Aficio 1085 Paper Tray 1 Jamming
you can change the tray setting in user mode to tray 2 and same time do not fill the tray one. same apply on print job from a computer, select tray two as default with print driver.
Jan 07, 2008 | Ricoh Aficio 1085 Laser Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
2,965 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
