Pace tdc779x hdmi problems - Televison & Video
Turn off the DVR, then hit menu. Turn the TV ONLY back on and use the onscreen menu to set the CC "on". The only problem I have is I wanted it to only be CC when I mute the TV, but this will turn it on all the time. Hope this helps!
Posted on Aug 28, 2009
I can not get the Closed Caption to work on my Pace HD-DVR TDC779X. I have been throught the Setup, The Televisions CC works (when I bypass the box).
Posted on Aug 22, 2009
Why did I lose the video signal from the receiver to the TV?
I assume you have tried both hdmi cables from box to tv. If both works good.Cconnect to amp. Connect cable box also on other hdmi inputs like bd, dvd, etc to make sure the spesific port is not faulty. If still no picture try to lower hdmi video display on cable box. You amp may not be able to display the higher resolution.
May 06, 2015 | Onkyo TX-NR535 Receiver 5.2 Channels, 65...
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
Need bchdm 0682
I need the PCI of HDMI BCHDM-0682. WhatsApp I have to do to buying it and how much I will have to pay.
Could you answer to fabiopaceli2002@yahoo.com.br.
Thank you
Fabio Paceli Anselmo
Jul 17, 2014 | Onkyo TX-NR509
When my ps3 is on 720p or 1080i there is this white fuzzy line that oulines certain images on the tv such a faces and clouds and such.. but when its on 480p its fine.. i bought a new HDMI cable thinking it...
This happens when using hdmi for me, free to air digital tv is fine, but playing games has the exact same problems as you describe, and even dvd's etc do it, but not very noticeable at all, needs to be slow paced with a high contrast in in the picture usually.
May 29, 2010 | Sony Playstation 3 (PS3) Console
I bought a PS3 slim (120 gb) recently, & only have the one game so far - FIFA 10. For some reason when we play it with the HDMI cable connected to the t.v the gameplay is noticeably slower than when...
buddy lsn, go to the settings its in the left side of the main menu, there is an option about the game settings, video settings, audio settings... etc. now go inside every one of them and change the default setting to be suitable with HDMI okkkkk :))) if u still cant find it send me back and i will right down in details what should u do exactly cuz idont memories the menu :S looooooool
Dec 05, 2009 | Sony Playstation 3 (PS3) Console
Sony connectivity
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Dec 23, 2008 | Televison & Video
Connection advice needed
hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me (dodzio24@o2.pl) and i send you the best solution i can.
Aug 14, 2008 | Samsung Televison & Video
Dvd won't play through PACE hi def converter box, service electric cable ty
Why are you running hdmi to converter box? Run HDMI cable directly from dvd to new Panasonic plasma. The less things in between, the better the picture.
Dec 14, 2007 | Televison & Video
Televison & Video Logo
975 people viewed this question
Top Televison & Video Experts
Electro Med Services...
