Question about IBM Infoprint 1332 Laser Printer
IBM Infoprint 1332 paper jam
I'm getting a "241 paper jam, check tray 1" message on my IBM 1332. I've looked everywhere underneath and behind to find a jam and also replaced fresh paper and I continue to get a jam message. Any ideas?
  • 2 more comments
  • dvd6338 Nov 17, 2008
    same problem, except that mine is error 242 with paperjam on tray 2.
    paper will go through, but not when "session successfully started" when connected to an AS400 server
  • aasfour2009 Mar 17, 2009
    Error 242 jams all the time? any ideas?
  • ejohnston Mar 30, 2009
    Getting the message 241 clear paper jam, I have looked everywhere there is no paper jam. What is the problem?
  • Anonymous Mar 13, 2014
    242.16 paper jam check tray 2
One of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Posted on Apr 17, 2009
  • IBM Master
  • 1,684 Answers
A 241 error indicates the printer did not pick up the paper from the paper tray correctly. This type of issue is caused by worn pickup rollers. If you pull out the paper tray and look at the bottom of the printer you will see an arm with to rollers, this is the paper pickup assembly. The little tires or rollers have worn down and can not grip the paper to pull it into the printer right. These rollers are user replaceable the part number is 99A0070 and they are available here: http://www.ccl-la.com/catalog/product_info.php?products_id=94
Posted on Aug 21, 2012
Constant paper jams
Open the printer and with a blower clean it thoroughly.
This resolves the paper jam issue many times.
Nov 16, 2011 | IBM Infoprint 1332 Laser Printer
How do I clean the rollers on my IBM Infoprint 1332??
I most cases if you are having paper pickup issues with this unit the rollers will be worn down not just dirty. The pickup rollers that pull the paper from the paper tray on the bottom of the printer are not very expensive, they run about $4.00 We carry them in stock at: http://www.ccl-la.com/catalog/index.php?cPath=24_59_60 Replacing them would be much better than just cleaning the rollers. If you pull the paper tray out and look under the bottom of the printer you will see 2 small rollers with rubber tires on them. These are the pickup rollers, they should feed rough, if they feel smooth then they need to be replaced. We also carry the full preventive Maintenance roller kit that includes the pickup rollers, charge roller and the transfer roller. We provide full tech support for all purchases too.
I hope this helps, if so please rate our solution,
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 07, 2010 | IBM Infoprint 1332 Laser Printer
IBM 1332 printer error #241 Paper jam
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
  • Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Oct 04, 2010 | IBM Infoprint 1332 Laser Printer
Hello I am getting a paper jam error #241 "check paper tray 1 "
DEAR SIR,
Some print media, although they may conform to size and weight specifications, may not perform to your expectations. Print quality, jam rates, fuser life, and output stacking can be affected by the printing environment (temperature and humidity) and characteristics of the paper (structure, moisture content, smoothness or thickness);
Duplex printing is not supporteD
Using Auxiliary tray is recommended
HOPE THIS HELPS....
Thank you sir,take care
How many pages per minute on a InfoPrint 1332
The InfoPrint 1332 has a maximum output speed of 35 pages per minute. This speed can be less if you are using thicker paper or paper that's not 8.5" x 11", and other factors can affect the speed as well.
Apr 14, 2010 | IBM Infoprint 1332 Laser Printer
What is this ??
Typically there is a piece of paper caught in the fuser exit. If no paper evident(ie paper feeds cleanly, stops 1 inch past fuser) verify there are 2 sensor exit flags present and free to move. Occasionally 1 of the flags gets broken off the sensor causing this jam.
Jan 27, 2010 | IBM Infoprint 1332 Laser Printer
I keep getting a Load MP Feeder Letter message. I can't clear what to do?
MP Feeder refers to Multi Purpose Feeder or Manual Paper Feeder or just plain bypass feeder. There should be a door that folds down to gain access to your MP Feeder tray. Try loading letter size paper on this tray.
Nov 24, 2009 | IBM Infoprint 1332 Laser Printer
Will not print to tray two message tray one empty stops
YOU NEED TO GO TO THE WEB MENU AND SET YOUR PRINTER TO AUTO SELECT TRAY AND SET BOTH TRAYS TO SAME EXACT PAPER TYPE
Feb 13, 2009 | IBM Infoprint 1332 Laser Printer
Infoprint 1332
in valid cartridge refill
Oct 21, 2008 | IBM Infoprint 1332 Laser Printer
IBM Infoprint 1332 Laser Printer Logo
2,048 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
