Question about Tomtom GO 910 GPS Receiver
Tomtom GO 910
My tom tom GO910 dosent work . When i charge it the green light turns on and when i trake it off the tomtom still dosent turn on . Is my battery dead or is it broken?
  • 4 more comments
  • Anonymous Aug 21, 2008
    restart help
  • Anonymous Aug 26, 2008
    Tom Tom has a red empty battery symbol green light is on while plugged in but tom tom does not work
  • Anonymous Sep 21, 2008
    Same here!
  • ssamuels Apr 23, 2009
    MY MACHINE IS JUST OVER TWO YEARS OLD AND A SECOUND ONE A BOUGHT FOR A FAMILY MEMBER. Both died this week with same problem. Green light is on when charging or trying to turn on but it will not turn on. Tried doing a reset. Nothing
  • Anonymous Apr 23, 2009
    kakivdm!! thank you so much!!
    You are a genius LOL:0)
    I tought i got a dead unit!
  • shoptotal Apr 23, 2009
    kakivdm i have the same problem here!
    If i hold firm they charge ...
    How can i fix it? Do u have any idea? Is it just a contact problem?
    Thanks,
    ANdre
We have the same problem. It is a problem of contact. We have the same issues with the car adapter and the home adapter. If you hold the tomtom real firm on the adapter, it might load again, but you need to hold it. That is not a great solution! TomTom knows about this problem, but they don't solve it!!!!
Posted on Oct 08, 2008
Check your battery symbol.
On mine, the battery is dead (or mechanically disconneced inside).
You need to reset the unit by pressing the tiny button on the back.
Problem is that when you remove the unit from the charging stand, the dead battery does not allow you to press the reset button. (Pressing the reset button with no battery cannot reset the unit)
IF you could press the reset button while plugged into the charger, you could get you unit working again. But..alas, the design of the unit prohibits you from doing so.
Chances are if you fix the battery problem, you will have a usable unit again.
Posted on Sep 25, 2008
    Sniper:
  • 171 Answers
Look at the contact pins (copper pins on the bottom of the tt) and check if one is bent or out of place. The negative pin (the one on the far left with the lcd screen facing away from you) is the one that causes the most problems. The positive side is the pin to the far left. If you have a OHM meter check for continuity between the pin and the solder joint directly below the pin. If you get a reading then it should be OK. If not there is your problem. Even with a dead battery you should be able to connect it to power and operate your tt, but it will die after removing it from power.
Hope this helps
Posted on May 04, 2009
Same problem with ours, took it back to the shop (Halfords) after 18 months, they sent it to TomTom who replaced the internal rechargable battery and now it's OK.There was no charge for the fix.
Posted on Oct 22, 2008
Hi my tom tom go910 wont turn on but the green light is on when its connected to the charger
First, check and make sure your battery is fully charged. Then try to do a "Reset" .... by pressing and holding down the ON/OFF button for 5 seconds (or a lot more) until the device powers on again. Yes, at times, it may take a minute or more ! of holding that button down.
Sep 17, 2011 | Tomtom GO 910 GPS Receiver
Cant plaY MUSIC ON TOM TOM GO 910
Place all mp3's in a folder named mp3
Then it shall find the files...
Apr 29, 2009 | Tomtom GO 910 GPS Receiver
Common problem with TomTom GO 910
Others have found this site helpful with the 910
Dec 12, 2008 | Tomtom GO 910
TOMTOM 910 will not turn on after charging
According to Kevin A who says, and thanks by the way (There is a reset button on the back at the top of the unit. It should be on the right side as you turn the unit around. Insert a paperclip or pin into this hole, and the unit should reset) at it works 100% because I tried this morning after being quoted £55 to have my GO910 fixed and now it works after the price of a paper clip. Doug rrp3
Nov 21, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910 sat nav.
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Mar 25, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910.
Mar 23, 2008 | Tomtom GO 910 GPS Receiver
Tomtom
stevi at the back of your tom tom where your windscreen dock goes there is a small rubber bumper if you look to the right and down you will see the reset button it is a small hole above the dock socket. sandy
Feb 21, 2008 | Tomtom GO 910
TomTom go 510
COMMON PROBLEM SO FAR WITH THESE. IF STILL UNDER WARRENTY CALL TOM TOM THEY WILL REPLACE THE BATTERY UNDER WARRENTY
Feb 20, 2008 | Tomtom GO 910
Tom tom 910 map no found bloplem
i knew tomtom 910 the best gps . so that why i buy it , but some time has bloplem i need help . if any want gps i recomender that buy the tom tom 910 is work for that money cause i got 1 year and now i bether and knew many new location .
Jun 19, 2007 | Tomtom GO 910 GPS Receiver
Tom tom 910
Try pressing the reset button, check your documentation for the location...but it's at the connection interface.
May 21, 2007 | Tomtom Go 910 (Europe, USA and Canada...
Tomtom GO 910 GPS Receiver Logo
431 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
