Question about Navman Trackfish 6600 GPS Receiver
Missing the target.
My position on the map is off. I can get close to a target e.g. "fish haven" etc. when I'm on the water but my position shows me about 300 yards away. Is there a way to recalibrate my position?
I had the same probelm.
Check that you are using the right time zone in your settings particulary if there is daylight savings adjust your time zone accordingly in your settings
Posted on Nov 09, 2008
P1296 code 1996 Concorde
P1296 CHRYSLER - 5 Volt Reference Voltage Missing At Throttle Position Sensor
https://www.autocodes.com/p1296_chrysler.html
Mar 02, 2017 | 1996 Chrysler Concorde
My hummingbird rf15 smartcast fish finder has stopped scanning.it still provides the water temperature but it no longer displays the depth and does not scan the bottom.
The Smartcast system uses the wireless version of a simple transducer and thermometer to locate fish, show structure and water temperature. From your description, it sounds like the transducer portion of the Smartcast device has stopped working.
Transducers are both simple and complex, sturdy and delicate. Here is a Science Minute: A fish finder electrical signal is sent to the transducer. The electrical signal to energize the transducer crystal is generated by an amplifier. The energized crystal reverberates at a particular frequency, to convert the electrical signal into mechanical acoustic or sound energy. The acoustic energy or sound waves causes oscillation of the water molecules through which the sound travels. The sound is pulsed out in a defined beam. These do not travel out in a straight line but in a wave pattern. The acoustic pulse travels through the water at a rate of approximately 4800 ft (1500m) per second in saltwater and 4920 ft/sec in fresh water.
The problem is that the crystal in all transducers (permanent mount, thru-hull mount and castable) is delicate. It is a crystal. Unfortunately the warranty on most of these is six months, and unless yours is newer than that, you may need to buy a replacement castable. The handheld unit should still work. While I think the idea of knowing what is "over there" is a good one for shore fishing, I haven't bought these systems because I could never get over the idea that repetitive casting of a crystal, no matter how well-housed, was a good idea. Good luck.
Sep 27, 2011 | Humminbird Smartcast Rf35
Where can i find a printable page to print all the controls and functions on lock on moder air combat please help
Scroll Lock Key nearest air target Alt + Scroll Lock Key center-of-view air target Shift + Insert Key next air target Shift + Home Key previous air target Shift + Scroll Lock Key nearest ground target Ctrl + Num Lock Key center-of-view surface target Shift + End Key next surface target Shift + Delete Key previous surface target
MISSION EDITOR Ctrl + N Key create a new mission Ctrl + O Key open an existing mission Ctrl + S Key save the active mission to disk Ctrl + Shift + S Key save the mission under another name Esc Key delete the current selection on the map Delete Key delete the current selection on the map Ctrl + Shift + C Key assign the active mission to a class and protect it with a password Ctrl + Shift + D Key declassify the active mission Ctrl + H Key hide or show specific objects on the map Ctrl + 1 Key return the map to the default magnification level around the crimean peninsula Ctrl + + Key magnify the map by a factor of 2 Ctrl + - Key scale the map down by a factor of 2 Ctrl + O Key take the view down to a very close level Ctrl + V Key magnify the map to a regional view centered on the selected object Ctrl + B Key view and edit the mission briefing Ctrl + D Key view a debriefing when a saved mission is loaded Ctrl + F Key start the current mission Ctrl + N Key begin a network multiplayer session Ctrl + M Key chat with other players during a multiplayer session Ctrl + R Key start the mission and record a video sequence Ctrl + P Key play back the last recorded video sequence Ctrl + V Key start the video sequence and enable its editing Ctrl + Shift + F Key specify failures that may happen to your aircraft Ctrl + Shift + W Key specify meteorological conditions Ctrl + Shift + E Key open encyclopedia Ctrl + Shift + O Key open options screen F1 Key help F2 Key keyboard command list
Feb 27, 2011 | Video Game Consoles & Games
Getting water in pistons and of course oil.Is it
There are Flapper plates in the exhaust. They can burn out especially when running with the Muffs for winterizing. Then problems shows up first time you take it out. Usually this problem does not show while boat is moving. The bad flapper allows water to draw up into the engine like having a straw in a drink.
Sometimes when decellerating or Transom to the waves a rush of water goes past failed Flapper and into engine. Instant Hydro lock.
Its easier to change the Flapper than removing a head and you know which exhaust to target. When you get the Flapper out, the parts guys can easily tell you if its junk.
May 10, 2010 | Boating
Bad smell that won't go away
try a bowl of white vinegar for a week or so. m just dont spill it!!
Sep 21, 2017 | Amana 22.6 cu. ft. Side-By-Side...
1994 jeep wrangler backfiring missing,
The problem is one of your coil packs is bad. Don't throw money into sensors, they are false codes. The problem is coil packs.
Feb 20, 2010 | 2004 Jeep Wrangler
Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Jun 15, 2009 | Boating
Some POIs are missing.
Nothing.
Not all business's will show up. Try putting in their address's.
Also do you have the latest maps. New maps are released about every 4 months. I bought the life time maps upgrade for $99.
Or, you can buy new maps when you want, but the are about $80 each. Ouch on that!!
Jan 04, 2009 | Garmin nuvi 250W GPS Receiver
Hitman - Blood Money
..it happened to me....that stage does not show the target....so try to kill everyone
Sep 16, 2008 | Eidos Interactive Hitman: Blood Money
Navman Trackfish 6600 GPS Receiver Logo
105 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
