Question about Microwave Ovens
I have an Amana Radarange AMV1154BAW that has stopped heating. Everything else seems to be working as it should, except that it doesn't produce any heat. I've seen suggestions that it could be the diode, capacitor or magnetron, but I'm not positive on where these are at or how to properly test them. Any suggestions would be great, or it you could tell me where I can find the service manual, I could probably figure things out from there. Thanks.
  • 1 more comment
  • fifo23 Aug 21, 2008
    Everything seems to be working normal, except that it doesn't heat anything. It's always been rather obnoxious as far as noise, but I don't think it's any louder than normal. To the best of our knowledge, there were no abnormal noises when it was turned on. Thanks for your help.
  • tamis04 Sep 08, 2008
    It seems like everything works, sounds fine, looks fine; BUT not warming anything (at all).
  • William Miller
    William Miller May 11, 2010
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises?
    Is it louder or quieter than usual?
    I have the service manual and can point you to it online.
  • Microwave Ovens Master
  • 9,098 Answers
Chances are it is a bad connection on the FA terminal of the magnetron, or a bad magnetron, or a bad high voltage diode.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Aug 21, 2008
Everything is working fine on the microwave, except that it is not heating the food.
this a problem with your magnetron.some units have a five to ten year warranty.they need to be replaced by a service tech
Feb 23, 2010 | Amana Radarange Microwave Oven
Not heating food
likely the magnetron is gone. check your warranty on this part with you book. otherwise it is a costly repair.
Oct 04, 2009 | Amana Radarange Microwave Oven
Amana Microwave stays on when I shut the door.
It'll be a bad door switch or a loose door switch mount.
See :
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
William E. Miller
prototech@usa.net
Sep 09, 2009 | Amana Radarange Microwave Oven
We have an older Radarange over-stove microwave oven with touch pad controls. Whenever I boil something without a lid for a longer period, some of the buttons stop working. Usually, they begin working...
Call Amana customer service. Microwave ovens should be able to handle the high humidity you are talking about.
Here's the contact information:
Have your complete model number ready. You can find your model number and serial number on the label located on the upper or lower
front facing of the microwave oven opening, behind the door.
For assistance or service, call 1-800-843-0304.
If you need further assistance, you can write to Amana with any questions or concerns at:
Amana Brand Home Appliances
Customer eXperience Center
553 Benson Road
Benton Harbor, MI 49022-2692
Aug 05, 2009 | Amana Radarange Microwave Oven
Help setting clock on amana radarange microwave made in 1987
press Reset, then enter in the time of day (e.g. 0807 for 8:07 am or pm doesn't matter), then press Clock button twice. hope this helps.
Mar 17, 2009 | Amana Radarange Microwave Oven
Amana radarange microwave oven 1000 watts not heating.
The two possible causes are a faulty door switch and a bad magnatron. You can pull the top cover off of the unit and check all of the door switches (there are 2-6 of them all on a common rail, me normally closed)). If the door switches all check out, replace the magnatron, diodes, and capacitor.
Oct 27, 2008 | Amana AMV5164 Microwave Oven
Instruction manual for 1986 Amana Radarange microwave
I think it will use a standard generic probe for the Accu-Temp. Sorry I couldn't help. Take care.
Jan 14, 2008 | Microwave Ovens
Microwave Ovens Logo
81 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
