Question about Compaq Presario X6000 Notebook
Compaq Presario Laptop powers on but turns off in less than a second
My compaq presario laptop powers off as soon as i power it on. This happens in less than a second. Initially I thought it was the battery but it does not work even with direct power turned on. Is there a problem with motherboard or power circuitry. What troubleshooting would you suggest before I take it to a service center.
Thanks in advance
  • 1 more comment
  • mkitright Jan 24, 2009
    My laptop does the same thing. Sometimes i can make it to the boot screen and acts like it's going to start and turns off. Sometimes it turns on and right back off. When it's plugged in the charge light is on. I'm at a lost!!!
  • Anonymous Apr 15, 2009
    MINE DOES THE SAME THING AND IT'S SO AGGRAVATING!! It'll turn on then turn right back off, how do I get it to stop?
  • Anonymous Apr 30, 2009
    Same issue here.
    The problem started as I would be ok after a few hours, then poof- shutsdown.
    In the last 2-3 weeks the power turns off more often. And now, most of the time when it boots up, it powers down.
    Everytime I have to wait for the greed light to re-appear.
    About 1.5 yrs ago, I did have the battery and adaptor replaced. And even today, I dont even use a battery. I just use the adaptor.
    This laptop I still like. Plays many games really well.
    Thank you
  • 177 Answers
Before I can help you ,I need the model number or the "service tag" number off the bottom of the computer.
Whenever you ask a tech question you must always begin with a model number / part number,etc. HP makes hundreds of different model Presario Laptops and each has it's own quirks. Only with a model number can an accurate diagnoses be made.
Posted on Jul 24, 2009
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like
Dec 29, 2012 | ASUS K52n-a1 Notebook
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
May 12, 2012 | Compaq Presario M2000 Notebook
Send me the laptop screen information
At first glance, we wouldn't elect the Compaq Presario M2000 the laptop we'd most enjoy cramming into a carry-on bag, but this economical desktop replacement is lighter than it looks, and it performs solidly.
The Compaq Presario M2000 is big and square--1.8 inches tall, 13.2 inches wide, and 11 inches deep--but it's very portable at 6.4 pounds. The power adapter adds less than a pound more.
Jun 01, 2010 | Compaq Presario M2000 Notebook
My compute will not turn on
The laptop might be overheating, sometimes when the laptop cant get any ventilation it shuts down and will not properly power up till the temperature issues are delt with.
But you usually get at least a few seconds of power before it shuts down again, so it may not be that, sounds a bit more like the CPU is dead and will need replaced.
Jan 03, 2010 | HP Compaq Presario CQ50-110US Laptop
Compaq laptop screen not working
compaq presario c304nrharddisk is not detecting
Jul 04, 2008 | HP Compaq Presario C304NR Notebook
Compaq F700 Battery live very less
Its normal, generally it comes with 80-90 min. You can use HP Power management to optimize the use of battery. Making screen less bright will increase the power backup.
Apr 28, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario X6000 Notebook Logo
249 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
