Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Wont recognize drive
Acomdata drive just stopped working.
I've has it less than a year.
it was making a click and spin noise constantly for about 2 days
blue solid light.
I turned it off and on again, and no luck.
computer will not recognize drive.
is there someway to retreive the data?
Help!!!!
I have 2 years of photos stored on it!
  • 1 more comment
  • sampowers07 Sep 21, 2008
    I've had this external for about 3 years.  I am using it with my ibook G4 and it has showed up perfectly fine until today.  The blue light on the front has not worked for about a year. every once in awhile it will make a clicking sound then stop.
  • hegseth Sep 24, 2008
    I have the same exact problem - have used for just about 1 year. It started clicking and now it when I turn it on it just blinks Red to Blue and will not come up on my computer. Three days ago I moved everything from my hard drive to it so that I could run install Norton and clean everything up.
    I have several thousands of dollars worth of onto this drive and can not access it. Please tell me that will be able to retrieve data. I am just sick about it right now.
  • Anonymous Mar 24, 2009
    what's that clicking noise!
    Problem Solver:
  • 8 Answers
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Posted on Sep 02, 2008
I had the same problem. its not the power cord its something internal in the hard drive its self.
although, the same noise coming from the drive was coming from the power cord box, so i have no idea what the problem is or how to solve it.
Posted on Sep 08, 2008
Acomdata HD120U2FE-72 120 GB external Hard Drive
OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
Feb 06, 2010 | Acomdata HD120U2FE-72 120 GB Hard Drive
Not recognized
Th prob lem could be most probably your hard drive casing not supplying the correct voltage and not enough for the hard disk to spin the moter so please connect the hd directly to the computer if its fine just change the external casing..
good luck
Jan 04, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Loud noise in slow down spin mode.
when it is in high spin then you stop the washer it makes a thumping noise until the basket stops sort of like a flat tire sounds to me like you need a drive block
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Acomdata hard drive Model HD320FES-72
Sounds like the drive has seized spindle... Not good news.
Is it buzzing similar to any of these noises: http://datacent.com/hard_drive_sounds.php ?
What you should do is remove the internal drive from the enclosure and connect it directly to the computer. If still buzzing then it's a real mechanical problem...
Nov 02, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Drive not recognized by desktop.
Aug 25, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Acomdata drive not recognized
the drive may have failed..... they can often be "fixed" long enough to retrieve data. i make alot of money from failed maxtor hard drives.
Robert
Jul 12, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Problem 2
The feint ticking noise usually indicates a dead hard drive.
The heads are flicking back and forth at random and make the ticking noise you hear.
The drive can still be detected because the physical hard drive and the controller board on it are in reality 2 seperate components working together. So the controller board is also trying to access the hard drive without luck.
If you have not dropped the unit or knocked it over etc, then chances are the controller board is what has died and therfore you still cannot access the drive. You may get lucky in finding a new controller board to replace a failed one and that will also get your data back.
May 14, 2008 | Acomdata 250GB External Firewire HD 250 GB...
Red light, "spinning, dropping noise"
There are some freeware that can recover data from problematic disks (like yours), formatted disks, repartitioned disks etc. since you said that the disk is recognized by the computer. You can try Disk Doctor NTFS, Recover My Files, etc. You may not be able to get all the files (depending on the problem of the disk which seems to be a spindle and platter problem), but at least you would be able to recover some.
I recovered a server recently just using one of these softwares.
Jan 14, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
959 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
