Question about HP COLOUR LASERJET CM4730 F MFP Printer
49.4C02 Service Error message on HP 3800dn printer
  • gina331 Aug 19, 2008
    Sheet of paper was stuck in printer. Removed the paper and turned off and back on and fixed the problem.
The paper will be removed later
Posted on Dec 05, 2008
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
That's a bit serious..this one under warranty?
Posted on Aug 19, 2008
pdouglasss
  • 125 Answers
SOURCE: hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Posted on Jan 10, 2009
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
  • 154 Answers
SOURCE: HP Laser Jet 2420dn - printer
a single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Posted on Mar 05, 2009
  • 191 Answers
SOURCE: hp laserjet 3800dn printer is showing 50.09 error
your pc in remover the printer and un instol the printer and again instol
the printer driver cd aply and chouse your printer and restart pc.
Posted on Sep 15, 2009
  • 4 Answers
SOURCE: Service Code 49 4c02
Try to upgrade the firmware on the printer, if that error still occurs after the firmware upgrade, you should try and use PCL driver rather than PS driver.
Posted on Sep 18, 2009
49.4C06 SERVICE ERROR For HP LaserJet 3800dn..Anyone had this code??
You need to update the firmware on the printer. This error indicates that the printer has received a print command it does not understand. Go to HP.com and search for updates for your printer.
Jun 27, 2016 | HP LaserJet 3800dn Printer
Error laserjet3800dn
Pl check error code once again.
Oct 16, 2014 | HP LaserJet 3800dn Printer
Can I make convert my HP laserjet 3800n into a 3800dn so i could print double sided automaticaly ?
You will need to buy a 'hp color laserjet auto duplex unit' to effectively turn your 3800n to a 3800dn and change the printer onboard controller but cost would probably more than buying a newer model with automatic double side printing support ... It is technically possible but I would not recommend it.
Sep 24, 2011 | HP LaserJet 3800n Printer
How can I solve the proble of 59 FO error code appear in the HP laserjet 3800 printer
The error says that "The transfer rollers in the ETB are not
engaged."
If replacing the ETB(electronic transfer belt) doesn't fix the problem, your printer is going to need a technician. Problem could be poor seating of the cables on the ETB motor or the 'transfer-roller separation solenoid or the DC Controller.
It could be a bad ETB motor or solenoid or DC Controller or high voltage power supply.
This isn't something that is going to be fixed by email.
I hope you have a service contract for your printer.
Feb 18, 2011 | HP LaserJet 3800dn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Hp laserjet 3800dn printer is showing 50.09 error
Sep 15, 2009 | HP Hewlett Packard LaserJet 3800dn Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
or home-grown
programs. On rare
Error.
the printer memory.
then on.
different software
program. If the job
the message appears
only with a certain
software program or
software vendor for
assistance.
or computer.
6 Remove all memory
from the printer.
DIMM and EIO device
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
HP COLOUR LASERJET CM4730 F MFP Printer Logo
2,257 people viewed this question
Seeker5211
Seeker5211
