Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Figidaire fridge leaks water
I by passed the internal hose and went straight to the freezer hose but water came out of the ice maker in a torrent.
Is there a pressure reducer inline somewhere? Or could I put a valve on my new bypass?
Kevin
  • 89 Answers
KEVIN THERES A PRESSURE VALVE ON THE INTERNAL LINE GENERNALLY RIGHT BEHIND COVER WHERE INTERNAL LINE GOES IN IF YOUR GONNA BUY A NEW VALVE BUY THE RIGHT ONE AND REPLACE IT THEY ARE NOT THAT EXPENSIVE AND FAIRLY EASY TO INSTALL AND WILL SAVE YOU ALOT OF HEADACHE HOPE THIS HELPS YOU GOOD LUCK
Posted on Aug 20, 2008
I have an old GE fridge with ice maker in freezer, water started leaking and flooded floor of freezer and started leaking outside freezer. What's going on & how do I fix it?
I think you need a new fridge/freezer. Look for offers now on sale some are quite reasonably priced and home Depot has interest free credit.
Sep 19, 2017 | GE Refrigerators
Ice maker dont work
There are several things that can prevent and icemaker from working.
1- Temp in freezer. If the temp in the freezer is higher than 6 degrees the ice makers thermistat will not call for water.
2- Water inlet valve. If the inlet valve is malfunctioning the silinoid may not be opening. Even if you are getting water through the door.
3- Faulty ice maker. If the internal components of the ice maker are no longer functioning it wont make ice.
To test the inlet valve. In the back of the fridge is and access panel near the bottom remove this panel and look at the inlet valve. now you should see 3 hoses. One is usually copper and runs directly from the house water supply. There will be two other hoses from the inlet. One leads into the fridge for the water in door feature. The other is for the icemaker. Switch the two hoses from the ice maker ( water in door and icemaker) than push the water in door feature and see if the water goes into icemaker. If it does not than replace inlet. If does and temp in freezer is below 6 degrees replace icemaker.
If you need further assistance please comment me back.
Jul 30, 2011 | Kenmore 53642 / 53644 Side by Side...
My ice maker has stopped producing ice - I have a whrlpool fridge freezer
Causes are:
1. Check shut off arm- If it fails to move due to lot stored ice cubs, remove some quantity of ice cubs.
2. Check the water pressure. Due to lack of water, it may stopped producing ice.
3.Check freezer temp: must be around 5 degree.
4.Check water hose has no leak. due to scarcity of water, ice maker could stop making ice cubes.
5. If water valve defective ice cube could not be made. To check the valve please follow this step.
Locate your ice maker, remove the ice bucket. Pull the coveroff the end of the ice maker. Locate the holes "V" and "L". Take a paper clip(jump clip) and tape. Straight the clip and put tape in middle. Hold the tapedside and insert the clip into "V" and "L". This sends the power to watervalve.If water goes into ice maker, water valve is good.Hope, is it helpful?
Jan 27, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is leaking water into the freezer
There should be a shut off on the copper line .cresent wrench
Nov 24, 2017 | Refrigerators
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge leaks water when Ice maker is activated by lifting lever
Either a loose or broken hose , or worse, a crack on the water valve.Pull fridge and check water valve and hose when signal calls for water.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking water from the ice maker
It is very unlikely that you have a leaking water line inside the fridge/freezer, as they are protected from damage. If you have water dripping from the ice maker inside the freezer and/or the dispenser in the door, the most likely problem is the valve that supplies water to the ice maker.
You'll need to replace the water inlet valve that supplies water to the ice maker. This is not the same valve that supplies water to the fridge (I believe the yellow colored valve) but rather, it is the blue valve, mounted just above the main water inlet valve.
At the bottom back right side of the fridge, you can remove the covering and see both the yellow and blue valves. The yellow one (on the bottom) is the incoming water control valve, while the blue (upper one) supplies water to the ice maker.
The part runs about $45-50 if you get it yourself, or around $185.00 for a repair person to come out and do the job for you. It should only take about 20-30 minutes to do it yourself with a small 1/4" nutdriver. Part available from Searspartsdirect.com or several other online and local stores. Just call around and give them your fridge model number and serial number, located on the inside of the fresh food section of the fridge - on the "ceiling" just inside the door.
Hope that helps.
Apr 08, 2009 | Maytag MZD2766GES Side by Side...
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Water leak where hose meets refrigerator connector
I had a similar problem several years ago with water leaking on the floor at behind the fridge. Turned out to be the gasket at a connection the same size as a garden hose at the water valve, so I used a garden hose washer and that did the trick. That was on a Whirlpool vintage about 1990. Can't say what the model was.
Mar 01, 2008 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
82 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
