Question about GoVideo Go Video DVD/VCR Combo
DVD Door opening problem
Have you been abale to resolve this problem? If yes, please describe solution. Thanks
I have a model DV1140 on my 4 year old son’s room since 2004 and I’ve seen this kind of issue before. This is mostly caused by trying to eject the DVD without pressing “stop” twice before ejecting it. But since you are already in trouble you may try this: First, let the player start to play the movie (you must let it play all the sneak previews first). Second, press “stop” twice (make sure the counter reads 0:00:00). Third, press “eject”. It should be working fine by now. If not, then you’ll probably experiencing the same issue I had today. My wife came to me complaining about the dvd player, she told me that she couldn’t get the player to eject the disc. “Women” I thought (sorry for that I didn’t mean it), but when I was trying my “magic” I heard an unusual winding noise coming out from the DVD tray. Since I couldn’t get the DVD to eject I decided to open up the player and check it for any loose or broken parts, nothing fancy anyone can do this. (If you don’t feel comfortable with this, just don’t do it and take the unit to a repair shop). Ok, now for the ones who stayed with me. Most important; first, unplug the unit from the AC outlet and disconnect it from all sources (TV, Cable, Sat, etc.). Remove a few Philips screws located at both sides and on the back panel and then remove the top lid, you should be able to see your disc by now. There should be another small black plastic “lid” on top of your DVD tray (this ensures the disc stays in place and centered), remove this lid by unscrewing another two Philips screws located on both sides of this “lid”. By now you should be able to remove your disc. After removing the disc you may try to plug the unit back to an outlet and turn it back on to look for any unusual sounds (like the one I heard) to identify any issues, (CAUTION: avoid any exposure to the laser beam). If you can’t find anything wrong yet then proceed to remove the front panel (it has a few clips all around just be careful not to break any of them). Now, check inside the DVD mechanism (a flashlight may be helpful here) when you look inside search for two small “pulleys” (mostly white)there should be a black rubber belt running around them if there is no belt around you’d just found half of the problem. If you are in luck you may find the little rubber belt (about an inch on diameter) or what is left of it inside the DVD tray. As soon as you find it you will have the other half of the problem. You see, when you press the eject button it activates a motor that spins the two “pulleys” I mentioned before with the help of the little belt you’d just found. This makes the DVD tray to move in or out of the player.
I hope this will be helpful for anyone out there with the same problem. (Remember, this work for my player (DV1140), I’m not totally sure that it’ll work for all models). As for me? Well, now I have to search for the belt p/n and were can I get two of them (one for spare). If anyone found it first you can contact me at:
Posted on Sep 08, 2008
I have lg dvd writer, model no. GSA-H55N .IT was running properly but today morning suddenly project disc is inside the writer and it is not opening at all.also their is no dvd logo on my...
u observe ur dvd writter cleanily k there will be a small hole in it insert pin in it the dvd writter opens k :)
Hope this helps & please remember to rate my answer. Thanks
Feb 18, 2011 | LG Computers & Internet
Lb@aol.comsony dw-q28a will not play getting a code 41. do i need just a up dated driver or a new dvd/cd? thanks any help appreciated. lisa
Hi Liglb,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not play a CD/DVD, chances are your CD/DVD componet needs to be replaced. Good Luck,
    • If this helps resolve your issue, would you please rate the solution.
Dec 29, 2010 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
Error Code DL and it won't run
Thanks for using FixYa. Error DL indicates door lock failure and it flashes when either the door lid is not closed completely and/or the Machine/motor control detects door lid switch is open. To resolve this issue you'll have to check the door lid/switch if it's fine then replace the machine/motor control however, the issue seems to be with the door lid. Please rate the solution if the issue is resolved or post a comment for further assistance.
Sep 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have just bought a sumsung external dvd writer se-so84c. Not only can I get any sound on playback dvd's although cd's seem ok, but also I am unable to record dvd's onto my sony vpcm12m1e which uses...
maybe your sound problem you can fixit with k-lite codec pack, download and install , you can use xp, vista . 7 etc, if cant burn use the last version of nero abalable
Aug 12, 2010 | Samsung Slim External DVD Writer Black ...
We have a Duet front load washer. The door is
Thanks for using FixYa. To resolve this issue Press and hold the END OF CYCLE SIGNAL button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jun 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Yes i have the problem too
Don't worry. There is a huge problem occurring right across the board at this very moment with the PSN Network. Some consoles are not synchronising trophies properly due to an internal clock error and this is causing problems exactly like you describe. It is expected that Sony will soon have this resolved.
For a full breakdown please look at this FixYa Tip.
If the solution helps, please leave a vote for it. Thanks.
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
I used the self clean feature and now the lock is locked, but the oven door cannot close because the lock mechanism is latched but the door is open...??What to do?
Thanks for using FixYa. From what you have described it seems that you'll need to replace the complete door lock assembly.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Jan 13, 2010 | Ovens
LVW-1105 DVD player/recorder
Yes, I did resolve my problem, I read one of the other comments and tipped it upside down and shaked it and at the same time Iam pushing the power button and it popped open. Thanks
Sep 30, 2008 | Televison & Video
DVD door stuck
Hello dont worry try to get a papar clip straighten it or a needle and fine out one small hole on the cd door or the face of the drive insert it and gently push your dvd will come out - sure
Jul 04, 2008 | Dell Computers & Internet
Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
GoVideo Go Video DVD/VCR Combo Logo
74 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
