Question about RCA F32450 32" TV
My RCA F32450 is whining as well
My F32450 (2002 model) when plugged in has a loud whine with no pic. Is the fix a IHVT # 257805?
  • tw_Ohio Aug 19, 2008
  • tw_Ohio Sep 03, 2008
    ok, found the focus by looking at the part that was removed. Still trying to dial it in, seems to be very difficult to get a clear picture again.
  • 1,694 Answers
Yes + replace the Horiz output transistor = part # 237470.
Then adjust screen control on new IHVT to same position as
original........ + or - a little bit OK. Then reset focus as needed..
Let me know how it goes.....................T.
Posted on Aug 19, 2008
I have a RCA 32 TV made in 2002 It shuts off and turn and nothing
If its a F32450 it is prone to two parts failing.
I presume you mean you turn it on and it shuts right off.
A question? I you unplug it and plug it back in do you hear a high pitched whine for a moment or longer/
This model (along with some others) has a problem where the High voltage Transformer fails.
It will usually take a transistor with it. I have fixed dozens of them and usually just need to replace two parts:
Transformer is location LL05 and part number is 257805.
Transistor is location TL02 and part number is 237470---generic number is 2SC5148.
The giveaway is if someone checks the transistor and it is shorted--the transformer got it.
I can tell you a place on EBAY that will have both parts for less than 30 dollars total.
Clearly, I do not know if you can do this repair--I do this for a living and replacing both parts in this set takes less than 20 minutes.
Let me know if you have questions and I will try to help you---
If this helped you at all rate this solution as I do this here for free.
Dec 19, 2009 | RCA F32450 32" TV
D52w23 rca makes an awful loud high pitched whine
This is a coil, now a NOISY coil.. It is a common problem, and happens often. The whine is caused by current passing thru the copper windings and making them vibrate! A commonly accepted repair for this situation is to squirt some regular old super glue into the copper windings and let it harden for a few minutes..Viola! no more whine!
Jan 28, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
36" RCA- loud whine/squeal when it is plugged in, otherwise no power.
The HOT Hortz output transistor has gone home, 99% of the time from a faulty IVHT (Flyback Transformer), very common on the ctc187cl* chassis. The factory Flyback is no longer available, I have had problems finding an aftermarket one to replace it with.
The HOT is a BUH517, but you can also use a 2SD5129. It is the transistor mounted on the siler heat sink with a metal clip rather than a screw, just in front of the flyback.....
If you replace just the HOT, most of the time you will get a rapid arc (27,000volts - BE CAREFUL!!!) from the lower (yoke) post on the flyback. If the flyback is shorted, It may also just burn out the HOT and go right back to "squealing"....
Good luck finding the flyback!!!
Oct 06, 2008 | RCA F32450 32" TV
The squeal maybe produced by the flyback, It looks like is a common defect on this chassis, but check any other defective part in the horizontal section and the power supply as well.
The fly back part # is 257805 but i would call RCA just to verify it or you can check inside the Tv's lid for that part number.
Check website.
Good Luck.
Jan 17, 2008 | RCA F36TF720 36" TV
RCA F32450 ATC113 chassis Dead & Squealing
IHVT # 257805 or ASTI 2078 = 20.00.......................T.
Dec 02, 2007 | RCA F32450 32" TV
RCA 35" TV
Bad IHVT transformer part # 257805 or ASTI 2078......T.
Nov 22, 2007 | RCA F32650 32" TV
Snap Snap Pop
Probable bad IHVT ( aka flyback transformer ) part # 257805
or Asti 2078...................................T.
Nov 09, 2007 | RCA F32450 32" TV
RCA F32450 32" TV wavy picture
Most RCA repairs on your chassis series require a new IHVT,
AKA flyback transformer . Inside an Integrated HVT are diodes
that can degrade and give the appearance of a bad cap....
Of course, you should check the electrolytics with an ESR
meter, just in case....
xformer part # 257805 or Asti 2078........T.
Nov 04, 2007 | RCA F32450 32" TV
RCA F32450 32" TV: suddenly shut off wont turn on
Followed Terryfic's solution. I am a DIYer and managed to order the part, desolder the old one and solder in the new one. However, when I turned it back on I got a black screen with sound. Hmmm, saw the adjustment screws but was hesitant. Ended up turning about 10 degrees one way and presto chango... Saved a $1200 upgrade to HD for a $30 part! Thanks
Oct 31, 2007 | RCA F32450 32" TV
RCA F32450 32" TV Logo
93 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
