Question about Maytag Neptune MAH5500B Front Load Washer
Od error my washing machine just started giving me an od error . . . is there anything that I can do or any way to bypass this error?
  • 639 Answers
Dear HAPPYFACE,
ngfam at you service!
Try to unplug it and then reboot it!
Otherwise
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
Posted on Aug 26, 2008
Amana washer error code
This is an open door error. check the latch and switch on the machine.
Feb 05, 2014 | Washing Machines
Hi! I have a maytag and it gives me OD error and it doesn't wash. As I push the button it gives OD on the digital screen. What should I do?
'OD' could stand for 'open door. If so there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 04, 2011 | Maytag Washing Machines
Maytage Neptune TL gives od error code. Tried unplugging the machine. Tried many things, but nothing is working.
Could be loss of signaling thru the left hand Lid lock;
Google "Sticky Neptune TL Washer FAV6800AWW" for the Service Manual and support for troubleshooting the OD error code.
Mar 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Hi! getting od error and waher will not let me start any cycle
Hello, the "od"error you getting means the control did not detect that the door was opened between washes. Try opening and then closing the door again and if the error message is still present, there may be a problem in the door switch mechanism, the electronic control or the wiring between the two.
Thanks
Jun 05, 2010 | Maytag Neptune MAH6700A Front Load Washer
Flashing od
If your machine is a FAV6800AW or FAV9800AW see if this post will help you clear the OD error code on your machine.
Sep 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Top load washer says door open ( od )and will not
did you tested your led switch? you can bypass lid switch just have to be very careful after that....if it is a bad lid switch better replace it....unexpencive and more safe
Aug 25, 2009 | Maytag Washing Machines
"od" error code Maytag Neptune FAV6800Aww
At 12 years of age, your Maytag may be telling you it needs to be replaced.
Sep 23, 2017 | Maytag Neptune FAV9800AW Top Load Washer
My machine has a code and is full of water
can you provide the full model # and also the full error message?
Sep 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag top load neptune washer error code od
I own a maytag neptune, top load washer with electronic board or lcd screen, od code display, those are the door switches locates on the side of the door, the switches are electronic, an after opening the washer an opening the switches I discovered that the wire that sends the signal from the switches to the board were broken an rotted from the mold an soap that got accumulated in the switch, I took the switch an cleaned all the electric contacts, an stripped the wire back to were the wire was in good shape an re-solder the wire back to the switch, assembled back together an had the error went away ( no need to do anything else), the switches are attach to the machine with a 1/4 in screws , if you are not handy with soldering wires, you can order the part, ask for the lid switch give them your model number an I think they run about 75 dollars each, time to change em if ur a newbie, maybe an hour , I can do it in maybe 20 mins tops!
try it hope it works for you!,,,,,,
new washer 600
new parts 150
making a wife happy...............priceless!
good luck! let me know.
Apr 19, 2008 | Maytag LAT3600A Top Load Washer
Od error code
I've been fighting the same problem for 2 days in frustration I just dropped the lid and it started working
Mar 31, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
56 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
