1st You download Webcam Driver.
I've been trying to install
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
SOURCE: Need a Driver and Software for GE EasyCam WebCam
Normal 0 false false false MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}To download the latest drivers for GE Easycam, please click the following link:
GE EasyCam Driver
After clicking, please select your OS and proceed to download.
Thank you and please rate the solution.
SOURCE: installation GE Easycam Webcam
You could get the drivers for your Easycam Pro for free and that would be enough to operate your webcam.
GE EasyCam Driver
SOURCE: need GE Easycam driver for Window XP
I have had this problem before on a system, you can download the Logitech WC-10 driver, they use the same chipset. I downloaded the WC-10 and it works great!
Download it from her http://www.logitech.com/index.cfm/405/&cl=ca,en?prodcrid=405
SOURCE: Can't get my GE Easycam pro, model #ho98064 webcam to work
down load split cam and install it from the site mentioned below run the software then connect your pc , open split cam from the progrrame, in split cam icon choose usb cam your cam shall work,
http://www.giveawayoftheday.com/freeware/usb/webcam-driver
thank you ,
domnickr
