Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper got stuck in printer
Hi
my printer is canon MP210 and paper is jammed
so please help me to get it out
  • 1 more comment
  • ooatsouid Aug 20, 2008
    I attempted to retrieve the paper from the back but it tore. I then managed
    to snag one torn piece but believe there may still be another inside which
    I cannot see. The machine will no longer pull paper through for
    printing.
  • jgilbreth Jan 09, 2009
    Digital read-out says E-3 (error code for paper jam) but I can't see anything anywhere that might be jammed. I first followed procedures for removing jam and then reset. It kept giving same error code. I turned printer off; unplugged from power source & printer; have changed paper type. Keep getting error code for paper jam. What should I do now? Can't use printer until error code disappears.
  • Anonymous Mar 22, 2009
    i've got paper jammed in my HP C3100 printer and i can't pull it out. what should i do?
I have a hpdeskjet 920c printer. There has been a piece of paper jammed in the computer and I can't get it out. I tried pulling from front, but it won't budge. Any suggestions?
NJM
Posted on Nov 16, 2008
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Open the back and remove the paper gently. if there's any resistance, take your time. DO NOT attempt to pull it through from the front
Posted on Aug 19, 2008
3 Suggested Answers
  • 6 Answers
SOURCE: paper jam under print cartridges
Stick a 9x12 piece of cardboard down into the tray to force out unseen pieces of paper.
Posted on Jan 26, 2009
  • 56 Answers
SOURCE: My Canon MP210 printer is
Try this:
Hold the RESET button then press POWER. While POWER button is pressed, release the Reset. Press Reset twice (always with Power keep pressed)
Release Power. You are now in Service Mode Menu 2.
* Wait until Power light turns to Green
* Press Stop/Reset three times within 3 seconds between each press.
* Press Power once to Set data. Now the light should change color.
* Open the printer and remove the ink tanks. The printer should be in replace mode.
* Reinsert the ink tanks.
* Close the printer and wait 20 - 30 secs.
* Press Power to shutdown the printer.
* Turn On the printer the 2 ink levels should be reset. Error should be removed. Source(s): http://www.toner2ink.com/
Posted on May 30, 2011
I have a Canon MP 210 with an E3 error message (paper jam) though there is NO paper jam. The paper feeder is spinning but doesn't grab the paper. Please help! Thank you, Robin
I think there is a paper jam or something stuck in the sensor that is making it think there is a paper jam. It may be a very small piece of paper which you have missed. Look again.
Jan 04, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Paper dosnt feed in printer pixma mp210 photo. HELP
Either paper jammed, stuck by foreign object or DRIVE ASSY faulty.
May 25, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Canon mp210 will not load paper this is a brand new printer so why error 3 continually?
E3 is paper jam.Make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.
Nov 10, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Hi, My printer will not feed-in the paper and will not print, also the laptop is not asking printer to print
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 05, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 paper jam
try to get in touch with canon service centre in your area and get it fixed it will be a small problem
Feb 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam under print cartridges
Jan 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I have an MP210 Canon printer.  It is saying E 3.  The alarm light is on.  When I try to print, it says there's a paper jam; there isn't.  Help?
i had this problem, i was convinced that there was no paper stuck in it, and in my frustration i ended up tilting it backwards and banging it on the table. i found a pen was lodged in the paper feeder. I was so relieved, until the error code was still flashing. then i stuck my hand down the paper feeder (take the paper out first) and found the smallest piece of paper stuck in it. try this.
i am so relieved.
Dec 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Front tray, paper jam
Please visit below mentioned links to solve the problem of paper jam:
Paper Jam Problem
Thank You
Oct 26, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
473 people viewed this question
old marine
old marine
