Problem for Washing Machines
Generic problem for all Washing Machines
I received an error on
I received an error on my Kenmore Elite Calypso washer of FL or could be F1 and I did not receive a manual with the washer to look it up. Can you help me fix this? Thank you
Best Solution
posted on Aug 19, 2008
Rank: Guru
Rating: 87%, 47 votes
The FL error code means:
Flood Condition:FL
flashes if any overfill condition occurs. This condition occurs when
excessive water in the tub causes the overfill switch to trip. The
control must realize that the trip was due to an overfill condition
instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10
seconds with no time-out. The pump is cycled in drain mode for 30
seconds on, 30 seconds off until the overfill switch resets or power is
discontinued to the unit.
Press STOP/CANCEL to clear the display.
The problem could be caused by a blocked or bad water pump but also there is a back up valve or flap in the drain assembly that also sticks and some times causes problems with the FL Error code . If you remove the back up valve flap this can some times clear the problem.
There seems to be a lot of problems of this nature with this washer on the web. It seems there is aclass action law suit between the consumer and Whirlpoos/Kenmore. The phone
number to call to get more information. 1-877-567-4297. There is also
have a website to download the claim form http://calypsosettlement.com.
Depending on when you purchased your machine you might be able to file
a claim.
also if you don't qualify for that there is a replacement motor that was designed for the unit that works better than the old one but still seems to have trouble occasionally;-
The pump part number of the pump is 8054954. Here's a direct link:
http://www.partselect.com/PartSearchResult.aspx?PartNum=8054954
It's apparently easy to change the motor, so give it a shot. It's cheaper than a new washer (and partselect.com
is even cheaper than Sears, who want $120 for a new pump... and
another ~$100 to send someone out to install it!!).
Popular Solutions for Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer
1 Solution
Questions and Unsolved Problems for Washing Machines
whirlpool ultimate care ii washer LSQ9110PW2
Westinghouse Washers and dryers
I was downloading a software from filehippo but by mistake it was cancelled by me & just ...
(More)
I was downloading a software from filehippo but by mistake it was cancelled by me & just 2mb was remaining out of 466 mb software. now i want to restart it from where i cancelled it, otherwise it will take more time to download again. Please help me...
dear sir i want to know how to oprating machine frunt loding
I have a Hotpoint Aquarius WM 62. The problem is, when I turn the programer to any of the required...
(More)
I have a Hotpoint Aquarius WM 62. The problem is, when I turn the programer to any of the required settings the machine starts with the water entering the drum, but there is no futher operations. the programmer dial stays in the same place, I.E. no further cycles.
