I cannot access my internet and my service provider says that i have to contact you to reset my router because it is saying the ip Adress is not there
  • 177 Answers
Try turning off the Router and on again.Tehn using Run>Type Command Prompt>Type ipconfig/all scroll down to see if DHCP is working.
Posted on Aug 19, 2008
I forgot my internet password
Hello
Type your network IP address, like 192.168.2.3 or 154.345.2.4 like that, you will have a network IP address of your own. Contact your internet service provider to know about this IP address. Type it on the addtess bar of your browser, even if you don't get internet access. Press "Enter" button. The confuguration menu of your modem will appear after few seconds, and you can select the password option and reset it. OK.
Feb 12, 2012 | NetGear WGR614 Wireless Router
I am installing a new printer(HP Photosmart d110 Series), it requires an SSID and IP adress.Where do I find these? Also, do I need anyother info from my Linksys router?
These information should be provided by your Internet Service Provider. If not, you may find it on a sticker or label at the bottom of the router. If still fails, you may try to access the router's page here . Just follow the steps.
Hope this helps.
Jun 19, 2011 | Linksys WRT54G2 Wireless Router
Hi! I tried to access to my Zyxel p660hw d1 with the common 192.168.1.1. ip adress in internet explorer, but it doesn't seem to find the router log in page... Ho can i access to it then?
Be sure that your router adress is 192.168.1.1 you can use winipcfg in windows (the gateway address is what you are looking for) to see if its the good adress.
http://support.microsoft.com/kb/141698
If its not working use another browser, simply restart the router or Hard Reset the router with a paper clip.
Mar 14, 2011 | Zyxel P660HW-D1 Router
Can't get access limits to work
there is no internet connectivity
check your router ip adress
check the computer ip adress is same range of router ip
if not,, please assign same range of router ip manually
please letme know this helpful
Jan 07, 2011 | Linksys WRT54G-TM Wireless Router
How to get the ip adress from a linksys rtp300 phone adapter
I'm not sure if your asking for the IP ADDRESS of your Linksys or the DEFAULT GATEWAY of that device because your router's ip address will be provided by your server or Internet Service Provider (ISP) depending on your service. There are two ways of obtaining an ip address first will be DYNAMIC, where your ip address changes all the time and STATIC where you are given specific ip addresses for example 192.168.0.1 -to 192.168.0.25. The easiest way to obtain those ip addresses, by the way, is to contact your Internet Service Provider (ISP)
example: AT&T, Roadrunner, Time Warner, etc....
But, if your looking for the DEFAULT GATEWAY for you to access your router's configuration, most of the time it is found underneath the router itself. For Linksys the Default Gateway is 192.168.1.1
>I hope i helped you out with this... Enjoy!
Sep 15, 2010 | Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA)...
Can not get access to menu ON ROUTER 2800G vigor. Have correct IP address of 192.168.1.2 but page will not load. Will a reset cure the access problem. Router is currently providing internet access
A reset would resolve this isssue but it would be reset to factory defaults, so you would probably have to get in contact with your isp to set the settings back for internet access.
When you type the ip address do you get a user name and password window up or just nothing at all? You try 192.168.1.1. And see what happens.
Feb 04, 2010 | Computers & Internet
When I try to access the internet it says that it can't contact the internet after going through the router the tray icon says it has a good connection but can't access it.
check your IP address..
check ur connection cables..
did you pay your connection bill?
contact your Internet Service Provider (ISP)...
if not solve....pls clarify everything...
Jun 11, 2008 | Computers & Internet
Zoom ap4 router
Unfortunately you need to be followed step by step in configuring your router, this can only be done properly by phone or with a chat service.
I think you did not saved the router settings before restarting the router. Go back to the router panel and type again the 2 DNS IPs provided and find the save all settings option on router before restarting.
If you cannot fix the problem in this way you can get support from Zoom at
US : (561) 2417170
UK : 08707200090
May 02, 2008 | Computers & Internet
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Ps3 internet
Have you tried to find the settings automatically? Your router may be stopping the ps3 from access it to retrieve the information
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
David Payne
David Payne
