Question about Nokia 3100
No signal no network access
  • Anonymous Aug 27, 2008
    no signal
  • Anonymous Oct 28, 2008
    My 3100 has no signal bars. I've tried reformatting it already and it's still the same.
  • 75 Answers
Might be ur area is weekin the netwok provider change ur netwok and check it out
Posted on Dec 01, 2008
Tip
Wireless Access Point Placement
Place your <b>wireless access point</b> in the average of you location. Almost all <b>wireless access points</b> appear with omni-directional antennas, which afford a doughnut arrangement signal in all directions. If you abode your <b>wireless access points</b> abreast a bank again bisected of your signal is activity out the door.
on Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
I need 3g or 4g network signal. Help
Some networks are still on 2g get in touch with your provider and ask
Mar 26, 2015 | Cell Phones
2700c no network access solution
My Dear Brother:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Dec 30, 2012 | Nokia Classic 2700 Cell Phone
Slow connection low signal
If a wireless network has low signal strength, the transfer of information across the network could be slow or you might not be able to access certain parts of the network. Here are solutions to some common problems with low wireless signal strength: Your computer is too far from the wireless router or access point. Move your computer closer to the router or access point. If your computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer. If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than the built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna. The wireless router or access point is turned off or isn't working properly. There are two things to try: o Make sure the router or access point is turned on and that the wireless signal light is illuminated. o Reset the router or access point by turning it off, waiting at least 10 seconds, and then turning it back on. If you don't own the access point or don't manage the network, contact the network administrator. There is interference from other devices. If you have 802.11b or 802.11g network hardware, it uses the 2.4 gigahertz (GHz) frequency. Other devices that use this frequency include microwave ovens and cordless phones. If you have 802.11a network hardware, it uses the 5 GHz frequency. Some cordless phones also use this frequency. These devices can cause interference between your computer and the network. There are two things you can try in this situation: o If any devices like these are near your computer, turn them off temporarily or move them farther away. o Change the router or access point settings to use a different wireless channel, or set the channel to be selected automatically if it's set to a fixed channel number. Sometimes one wireless channel is clearer than others. In the United States and Canada, you can use channels 1, 6, and 11. Check the information that came with your access point or router for instructions about setting the wireless signal channel. The network you're looking for is set to not broadcast its network name (SSID). Wireless routers and access points can be set up so that they don't broadcast the network name. In this case, you can't detect that the network is in range (in order to connect to it) unless you've previously connected to the network or you manually connect to the network using the service set identifier (SSID). To connect to a network that's not broadcasting, follow these steps: 1. Open Connect to a Network by clicking the network icon ( or ) in the notification area. 2. Click Unnamed Network, and then type the network information. The network will be added to your list of networks and will be available to connect to in the future when your computer is in range of the network.
Dec 27, 2012 | Computers & Internet
Network error
First Option:
Secend Option:
Oct 30, 2012 | PANDIGITAL Novel 7
My phone say's no access to network why
First Option:
Secend Option:
Sep 27, 2012 | Sony Ericsson K800i Cellular Phone
Cdma network is not accessable
First Option:
Secend Option:
Jul 25, 2012 | HTC Ozone XV6175 Cell Phone
Why is there no network service in my cellphone?
There might a temporary shutdown of signal in your area...or maybe no signal. Go to an accessible area with no signal disruption...if your phone still no signal...
Try this to see if the problem is no network... Go to your phone settings...go to search to network...the problem is no signal
Sep 21, 2011 | Computers & Internet
Wireless networking problem
Access points receive the wireless signal and re transmit it again.
Once you enter the web interface of the access point, you would have to connect it to your wireless network. Once that is done, you should be able to connect to the same network , with a stronger signal , from your access point
Thanks Ranjit
Aug 19, 2009 | Cisco Aironet 1100 Wireless Access Point ...
Nokia 3100 Logo
115 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
