Question about Xerox WorkCentre XD125F All-In-One Laser Printer
E2 red misfeed indicator/status code
I had a misfeed indicator, giving me an E2 status code. I have removed & cleared the paper path thru the fuser area, paper feed area & exit area, but the status code still appears & I'm unable to get my machine to work. What can I do.
  • millenia Aug 19, 2008
    My Xerox Work Centre XD 125f showed the red misfeed indicator after a paper misfeed & gave me a E2 status code. I cleaned the path thru the fuser, paper & exit area but the E2 status code still show & can't get it to work. My Xeros doesn't have numerical buttons except for 2, one for multiples of "tens" copies & another for "1" for more than one copy/ies.
    Master:
  • 638 Answers
This is the link
https://www.partsdrop.com/store/
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
E2 red misfeed indicator/status code - db4ad8a.jpg
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
Posted on Aug 19, 2008
    Master:
  • 521 Answers
The fuser is moved and lost its exact position should be again adjusted to its proper position.its simple.the error E2 means to adjust the fuser unit only.but without the technician at your place you cannot adjust it.still you can try removing the unit its very easy .just remove the screws after you remove the drum unit out.and try to adjust it.may it work if adjusted properly.or call the technician.its not major problem.do not worry.thanks.keep me updated.
    Master:
  • 623 Answers
Make sure there are no papers left on machine
    Genius:
  • 1,011 Answers
Check and fix the tray properly in the printer and reset all alarm coming..
if you have clean all the majors then finally you have to do it.
hope..
  • SALMAN NASEER Aug 19, 2008
    have u checked the fuser for brakage too.
  • SALMAN NASEER Aug 20, 2008
    dear,
    if u still invain to get it repair then u have to check it by some hardware expert..
    regards,
  • 659 Answers
  • 6,487 Answers
E-2 is a fake paper jams, fact of the matter is that E-2 means the main board detected a fault during self initialization . At the point of E-2 being displayed, open and close the clamshell. The original status code that caused the E-2 will be displayed. Then press the "0" key to observe the subcode. This will surely help you to further diagnose the situation.
Hope that helps.........
  • Mark Gil
    Mark Gil Aug 20, 2008
    Feel free to contact us back if you still need help and continue replacing that bad part of the machine...
    Good luck..........
How removed misfeed indicated problem?
a miss feed mean the roller could not get the paper, so clean the roller (s) or have them replaced, try a different paper draw
Jun 25, 2014 | Konica Minolta Di2010 Di2510 Di3010 Di3510...
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
MY PRINTER STOPPED PRINTING AND GIVES A ERROR MESSAGE THAT THERE IS A MISFEED. I CAN NOT SEE THE PAPER FROM THE FRONT OR TOP ARE THERE ANY OTHER SOURCES THAT I CAN CHECK TO CLEAR THE MISFEED, IF THERE IS...
You need to consult your manual for all the paper paths that you may have missed.
Check all paths and go out and buy paper path cleaner, follow the instructions on the package and completely clean out the paper paths.
This should loosen or remove the stuck paper and get the printer printing again.
Please write back results (good or bad)
Mar 16, 2010 | Ricoh Aficio SP C231N All-In-One Laser...
What does E 2 mean on Xerox XD 100
PAPER JAM PROBLEM
The Main PWB sensed that a paper jam
exists within the paper path.
E2 Status Code (Without SDF) RAP
The Main PWB sensed a tray misfeed or a paper jam in the paper path.
Initial Actions
• Switch off the power and clear any document jam.
• Check for any obstructions in the paper path.
Procedure
Switch on the power. Enter diagnostic code 30-1.
Open then close the Fuser Gate to actuate and deactuate the Fuser Jam Sensor Q3 while
observing the Paper Jam lamp. The Paper Jam lamp comes on and goes off.
Y N
Go toFlag 2 and check the wires for an open or short circuit.
Manually actuate and deactuate the Paper Feed Sensor Q1 while observing the Toner Cartridge
lamp.
The Toner Cartridge lamp comes on and goes off.
Y N
Go to Flag 1 and check for an open circuit.
Place a piece of paper above the Fuser Gate and use the Manual Exit Knob move the paper
across the Exit Sensor Q4 while observing the Drum Cartridge Lamp.
The Drum Cartridge lamp turns on and off.
Y N
Go to Flag 3 and check for an open wire.
Manually actuate and deactuate Bypass Feed Sensor Q2 while observing the Auto exposure
lamp.
The Auto exposure LED comes on and goes off.
Y N
Go to Flag 4 and check for an open circuit.
Press the Clear button. Enter diagnostic code 6-2. Press the Start button. The Registration
Roll Solenoid can be heard switching on and switching off.
Y N
Press the Clear button. There is +24 VDC measured between CN103-1 and GND.
Y N
Replace the Main PWB PL 7.1.
Go to Flag 5 and check the wires for an open circuit. If the wires are good, replace the
Registration Roll Solenoid SOL3.
Press the Stop button. Paper jams in the fuser.
Y N
Check the following:
• Ensure that the paper tray guide is set to the correct width of the copy paper.
• Inspect the paper path from this tray and the paper registration area for an obstruction
such as a burr.
• Inspect the Registration Roll, PL 5.1 and the Pinch Roll, PL 1.4 for contamination
and wear. Clean (with Film Remover only) or replace as required.
Apr 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Xerox WorkCentre Pro 215 E2 Error Code
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Nov 19, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox workcentre xd105f
It is entirely possible you have a small piece of paper that got ripped off somehow and it is now blocking the sensor leading the machine to think it has a paper jam.
Follow your jam clearance instructions again and pay close attention and rotate all movable parts in the jam area many times, then reboot the machine multiple times and allow the machine to completely come up before rebooting again, it may be necessary to reboot the machine 3 or 4 times to clear this error, each time following the jam clearance, if this doesn't resolve then you should have an expert take a look at the machine.
Oct 19, 2008 | Xerox WorkCentre M123 Copier
Xerox Work Centre XD 125f/E2 red misfeed indicator/status code
You're very much welcome, dont forget to rate my solution FIXYA from your original port , feel free to contact us back...
Aug 20, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
160 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
