Cannon MP160 says the ink absorber is almost full to contact service center. The onscreen manual refered me to this website
  • rray917 Aug 26, 2008
    My MP160 says the ink absorber is full and to contact service. What is this and how do I fix it?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Really? which onscreen manual? must be a fixya manual..this is available from www.canon.com
Posted on Aug 19, 2008
SOURCE:
How can i solve ''absober full on pixma mp160.''??
Greetings,
If your ink absorber is reporting full, you need to take it to a Canon service center to have it replaced and have the counters cleared. When you clean your print heads, the ink is stored in this absorber and it gets full over the lifetime of your printer. Go to the following link to locate a nearby service center.
Thanks
http://www.usa.canon.com/consumer/controller?act=ServiceLocatorAct&fcategoryid=257&modelid=11993
Apr 18, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Tip
Code error PIXMA MP160 All-In-One InkJet Printer
this error list PIXMA MP160 /150 All-In-One InkJet Printer
CANNON PrintersMP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported inkcartridge is installed ,
or the ink cartridges are notinstalled properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera /video camera does not support Camera
DirectPrinting
E14 The Ink cartridges whosedestination are wrong
E15 Ink cartridge is notinstalled E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature riseerror
E27 Waste ink absorberfull or platen waste ink absorber full
E28 Ink cartridge temperaturerise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
on Mar 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
I have a cannon pixma mp160 printer and i am repeatedly getting error 2 on the led display after replacing the cartridges. i have already tried reloading paper
ERROR CODE CANNON MP150/MP160
E2 2 No paper (ASF)
E3 3 Paper jam
E4 - No ink
E5 5 The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «??&raquo
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 15 Ink cartridge is not installed
E19 - Failed to scan head alignment sheet
Feb 01, 2011 | Computers & Internet
What is e 27 and e 8??
Those two are error codes, and they mean the following:
E8 - The waste ink absorber is almost full. Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc.
E27 - Manual does not specify what this means, but tells you what you should do: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I can't reset my E27 error code on my Cannon MP160
E 27 mean Ink absorber tank is full
Download this link http://www.canon ip ip 1500 service tools.com
Jan 14, 2010 | Canon PIXMA MP160 All-In-One InkJet...
ERROR E 2 comes up on the little lcd screen when i try to print now.
www.fixyourownprinter.com
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E15 - Ink cartridge is not installed
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Oct 26, 2009 | Canon PIXMA MP160 All-In-One Printer
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
Its appear " The ink absorber is full. Contact the service center."
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 11, 2009 | Office Equipment & Supplies
How to fix it
the ink absorber MUST be emptied on a regular basis. check this link(for drivers) and follow the Canon links to support and then user manual.
Mar 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Waste tank absorber is almost full ~ message
I've taken this from my manual.
This error message indicates that the ink absorber is nearly full.
The machine has a built-in ink absorber to hold the ink used
during FINE Cartridge cleaning, for example.
You can continue printing by selecting Continue*1
on the display on your camera.
However, because printing is disabled once
the ink absorber becomes completely full
and until the ink absorber is replaced, you
are recommended to contact a Canon
service representative as early as possible.
*1 To resume printing, you can press
[OK] (MP180) / [Black] or [Color] (MP160) on
the machine instead of selecting [Continue].
Feb 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Open Questions:
jasbo
jasbo
Ekse
Marvin
Marvin
