Question about Dryers
GE Prodigy Dryer DPSR483GA2WW - WON'T STAY ON
When I turn the Start/ON switch to ON the dryer starts right up. But as soon as I release the switch, and it goes back to Start, the dryer shuts off. Any ideas?
  • Big Steveb Aug 20, 2008
    It's a Profile not a Prodigy. Sorry.
  • Big Steveb Sep 04, 2008
    I fixed it myself without your help. It was the belt switch. Cost 8 bucks and now she works like a charm. Thanks for nothing Fixya!
Amigaman
  • 248 Answers
SOURCE: GE dryer starts but..... stops
The motor switch is not working properly. You can try removing lint from motor area around the end where the wires attach. This may free switch. If it still won't work you need a motor.
Posted on Nov 15, 2007
watugot
  • 290 Answers
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
futureloginn
  • 734 Answers
SOURCE: Drum doesn't turn, start switch
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Posted on Dec 02, 2008
ginko
  • 19396 Answers
SOURCE: Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 06, 2009
SOURCE: Not getting heat from dryer
check the high limit switch and glow rod
Posted on Sep 15, 2009
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
I have a GE Profile Prodigy eletric dryer that wont start. When I turn the switch it hums and stops when I let go of the switch, but won't start. Is that a switch problem or motor? How do I tell?
That sounds like to me the drum belt is broken..GE dryer use a belt switch that if the belt is broke will perform exactly as you describe ..as long as holding the start switch the motor will run and as soon as you release the start switch the motor will stop.
To check for a broken belt remove the top by removing the 2 phillips headed screws inside of the door at the top of it and pull off the top to see if the belt is in place and attached to the drum..if no belt seen when top off its broken and laying down in the base frame
GENE
Aug 28, 2011 | Dryers
GE Prodigy dryer makes an electrical buzzing sound when I try to turn it on and it won't turn on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
Turn start button. Dryer begins working; as soon as I release, the start lever it stops
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE dryer won't start up - sounds like the drum is stuck.
unplug it,open the door and look up.you'll see two screws,take them out and remove the top panel,then look around three or four inches down from the top and removetwo more screws,one on each side,this is harder than most dryers to work on,not much room to reach under the drum to remove and reinstall the belt,there's also one more screw down on the right hand side below the drum that has to come out also, just remember how you took it apart,if you start it and hear a loud humming sound that's the motor,hope this helps you
Feb 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
Dryer won't stay running
I had the same problem with my kemore. Thank goodness I still had it under warranty.
The tech said the door latch was just slightly ajar. This is common he said that when we take clothes out we let the door close to hard or gets ajar for leaning in to take clothes out.
He readjusted it and I have never had a problem with it again.
Hope this helps
Sep 26, 2009 | GE DBSR453EBWW Electric Dryer
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Dryer will not start
I had the same problem and this is how I fixed it ,,, i did a comfortor ,very heavy when wet .....next day i tried to do a new load ...when I turned start button all i got was a hum... I removed screws just inside door at top of lip this releases top of dryer,,,, exposing drum i rotated drum clockwise to check condition of belt ....looked good ....mine is 7 yrs old ...to soon to be motor problem ....so while turning drum i held start button on and finally motor kicked in and this solved my problem...you might be able to accomplish this without taking of panel ..though you wont be able to see belt ....by turning the drum from inside dryer while someone else turns on start button
Oct 25, 2008 | GE Profile Prodigy DPSR513GA Dryer
Dryers Logo
218 people viewed this question
Top Dryers Experts
