Question about HP Computers & Internet
Laptop does not boot at all
Hi, my laptop lights switches on,but it just does not boot up at all.
What can i do?
  • dooggie06 Aug 20, 2008
    no, the screen does not come on at all.
Does the screen turn on at all ?
Posted on Aug 19, 2008
Gateway 1450 Solo - power light on amber , won't boot
hi Does the laptop come on at all or just the light comes on
Mar 15, 2008 | Gateway SL1450-30165297 Notebook
Please help! I have a gateway NE51006u Intel celeron quad core processor N2920 windows 8 laptop. Recently it has been making clicking and notifying me that there is no bootable device. I have tried all...
Solution 1: Instructions for Performing the Power Discharge Procedure (ATX Reset)
Information:
Your computer has no power at all or cannot boot properly. In some situations this can be caused by an external device or an electrical problem. This can usually be solved by removing all external devices and resetting the power supply.
Instructions for laptops:
1. Disconnect all external devices you have.
2. Unplug the power adapter from the laptop.
3. Remove the battery pack from the laptop.
4. Press the power button and hold it for at least 15 seconds.
5. Reconnect the power adapter.
Do not yet reconnect the external devices, they should stay disconnected. Do not yet reseat the battery pack.
6. Switch your laptop on and test if it boots normally and watch if the power LED lights up.
7. If the power LED still does not lights up, continue with the next steps.
8. Disconnect the power adapter from the laptop.
9. Press the power button and hold it for at least 15 seconds.
10. Reseat the battery pack. Do not reconnect the power adapter.
11. Switch your laptop on and test if it boots normally.
Solution 2: Unplug and reconnect System Hard Drive
1. Unplug the power adapter from the laptop.
2. Remove the battery pack from the laptop.
3. Unplug and reconnect System Hard Drive. This is normally accessible by removing a panel at the bottom of the laptop or removing the back enclosure (see User Manual).
4. Reseat the battery.
5. Switch your notebook on and test if it boots normally
Jan 03, 2015 | Computers & Internet
NO Display in my laptop
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jan 20, 2012 | HP Computers & Internet
My samsung laptop will not turn on. How do I fix this?
Hi
Possible reasons why your laptop doesn't boot ( Power on with green light indicator lit)
-battery problem
-memory problem
-power failure
-etc ( maybe one of the hardware that is connected inside your laptop)
Troubleshooting steps:
1. First you need to try switching on your laptop without the battery
Basically you will remove the battery of your laptop and connect the ac power then switch it on.
a. If your laptop boot up ( with a green light indicator ) the problem will be the battery.
b. If the laptop does not boot up continue using step 2.
2. Unplug the power adapter , remove the battery and memory
Watch this video and it will help you to remove the memory
http://www.youtube.com/watch?v=kdDf46XKXiE&feature=related
NOTE: Your not going to upgrade your memory!
After removing the memory put it back close the panel and put back the screw.
Now after putting the memory , Try to plug the ac adapter and press the power button and check if your laptop will boot ( No need to put back the battery because your laptop will power up with out the battery )
If your laptop will still have the same problem the best thing to do is to bring it on the nearest support center for Samsung laptop because there's a possibility the problem will be the hardware that is connected inside your laptop.
I want to provide you the complete information on how to open your laptop however since your just new with this and to avoid any damages the best thing that you can do is to bring it on laptop specialist if the troubleshooting steps that I provided will not work.
Be careful Alright! Good luck
Have a nice day
Please rate my answer
Oct 27, 2011 | Samsung NC20-21GBK Notebook
I have a Fujitsu-siemens lifebook E-7010 laptop. The screen is not lighting up when i switch on the machine. The laptop hums normaly. the green light comes on, but the screen is not lighting up. Please...
You will remove the battery and unplug the dc adapter.After complete those hold down the power switch for 30 seconds.
Now install the battery and plug the dc adapter to laptop again and hold down the power button.I Nhope your problem will solve.
Dec 24, 2010 | Computers & Internet
Hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Have wireless internet but no connection to laptop. where's the switch on the laptop to turn it back on?
Hi !
Most of the laptop wireless switch is on the side of the laptop. If there is no physical switch, press the Fn+F2(wireless symbol) to enable the laptop. Double check the wireless LAN if enabled in the system setup. To access system setup, press F2 while the system is booting-up.
Hope this helps !
Thanks.
Jan 23, 2010 | Dell Inspiron 1526 Laptop
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
Laptop wont switch on fully
Did you press F8 as you boot up to get boot up options and did try the Last Known good Configuration and Safe Mode?
If these didn't work I suggest you re-install Windows.
Apr 10, 2009 | Acer Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
