Question about Microwave Ovens
Samsung microwave turns on by itself
Sir: I have a Samsung microwave, model # MW1430WA. Of recent, the microwave has started turning on by itself. I see you mentioned that this problem is caused by a failed keypad. Please tell me how I can get this replacement part for this microwave. Thanks for any help.
Shameer Khan
  • jeremiebouch Oct 07, 2008
    I have the same problem with this microwave, model # MW1430WA have you found the parts ??? I cannot find it
  • Microwave Ovens Master
  • 9,011 Answers
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can order Samsung parts here.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 21, 2008
Microwave starts by itself
Likely a microprocessor/control panel issue. Microwave ovens that sit over ranges often have electronic failures due to heat, humidity, and grease, from the range below, which come into contact with their main circuit boards.
Apr 16, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
Aug 29, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
I just turned on the microwave (samsung) and it started for a second then turned itself off and now it is doing nothing.....
HELLO.
This is the step by step solution.
Check if there is live power on the outlet.
Make sure the microwave plug is fixed properly on the outlet.
If the problem is not solved,then change the fuse placed behind the microwave that is used to control power suppl to the microwave.
Thanks.
Sep 19, 2011 | Samsung Microwave Ovens
Samsung microwave MW1430WA often refuses to respond to any control buttons. Sometimes it shows ''ON'', sometimes ''OFF'' and on these occasions will often restore Time by pressing ''Pause/Cancel'',...
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
You have a failing membrane keypad.
On some models, you have to peel off the old one and replace it.
On some models, you remove your controller and move your circuit board into a new frame with a keypad already installed.
FixYa is not currently notifying us when Clarification Requests are answered, so please contact me directly with your full model number from the tag on / in the unit and color so we can help you with free do-it-yourself tips and/or an estimate.
William E. Miller
prototech@usa.net
Oct 05, 2009 | Samsung SMH7178STD Microwave Oven
William E. Miller
prototech@usa.net
Oct 05, 2009 | Samsung Microwave Ovens
Samsung microwave
I have a Samsung model 1032BB in my R.V. Starts up all by itself and then I can't turn it off/on; have to unplug it. Should I have it repaired or should I replace it?
John
Sep 06, 2008 | Samsung SMH7178STD Microwave Oven
Keypad for Samsung microwave
To find out about Samsung recalls, please call Samsung's Service Division at 800-932-3837.
Please let us know what you find out so others can benefit.
Aug 20, 2008 | Samsung MW1030WA Microwave Oven
Microwave turns itself off after a couple of seconds
try to press in on the door after you strat it or down on the door after you start it your interlock switches my be going out
Jan 22, 2008 | Thermador MBYB Microwave Oven
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
UPDATE: GE Spacemaker XL1800 Microwave
JVM1850BD002 is a correct model number. This is a GE made by Samsung. It sounds like the motor or coupler is bad. More likely the motor. If you grab the motor shaft and try to gently turn it, it may grind or slip a lot. That's a sign of a bad motor. If the coupler is bad, it will be cracked or broken, causing it to slip on the motor shaft or the turntable itself. The coupler is reference 40, and the motor is reference 43 on this handy exploded view drawing: http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00016500/00016593.p01.pdf (copy & paste whole URL) Here is the GE part price info on these two parts: DESCRIPTION DRAWING PART NO. PRICE MOTOR-SYNCHRONOUS 43 WB26X10038 $46.00 COUPLER 40 WB06X10144 $8.75 If the motor is bad, you might be able to find the Samsung part number printed on the motor label and look it up at http://www.samsungparts.com They often have parts for far less than the expensive GE parts.
Dec 01, 2006 | Samsung MW1030WA Microwave Oven
Microwave Ovens Logo
765 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
