Still getting FH codes
Checked all wiring, hoses & still getting FH error code. Thanks!
Maytag Duet GHW 9100 LQ1
  • Debra Kelley Aug 23, 2008
    We tried that & everything seemed to check out ok. We actually found a pop bottle cap in the washer drain basket. Took it out & started a wash cycle. Got the Error code again so I reset the washer & it washed through the cycle w/o problems. I had a tech come out to look at the washer & he advised me that a common problem with the Duet front Load washer is if the drain basket get debris in it, the washer will automatically set off an error code. The tech also identifed that the water pump was starting to fail so we purchased a new one to install before it completely fails. Thanks for your efforts!
  • jaedeevee Aug 30, 2008
    The problem started a few months ago and now it seems to be getting worst.  We would get an FH error on our HE3 during the rinse cycle.  We'd press the cancel button and it would usually say there's 1 min left in the cycle.  We'd then press and hold the start button and the cycle would start and finish without problems.  Now the FH error is coming up as early as 1 min into the wash cycle and it comes up a few more times throughout the wash and rinse cycles. We're doing the same thing to get rid of the error, but I know that's not the solution.  HELP!!
  • 958 Answers
Does you unit have this water sensor at the bottom part of the unit?... if so..sometimes they get too sensitive and dictates an error message.
you can experiment by dsconnecting this wire and if it does not change anything, then short the wires. i am not sure if this is a normally open switch or a normally close switch.
if you jumper a wire on the two wires and it indicated a different error code, then it is a normally open switch. remove the jumper wire and w'e'll continue trouble shoot your unit.
tnx for using fix ya.
drcool
Posted on Aug 19, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Maytag Epic FH Error
follow this steps .God bless you
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
Jul 22, 2013 | Whirlpool Duet GHW9150P Front Load Washer
FH SIGNAL MEANS ......... WHAT IS THE USE OF FH SIGNAL........ AND APPLICATIONS
The error code FH means no water is detected entering the machine which can be due to a faulty flow meter not registering the correct amount of water that has passed through it or the pressure is not tripping from the empty position to the full position when the correct water level has been reached. Your machine is definitely made by Whirlpool like other Kenmore and Maytag washing machine so they are basically the same and troubleshooting is then the same. The link below contains the detailed troubleshooting of this error code for a Whirlpool Duet and should be applicable to your machine.
Error Code FH on Whirlpool-made Front-Load Washers
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Code F1, does not stop filling, water pours out of soap tray
Are you sure it's not an F/H error?
The F/H code means the unit isn't detecting water fill at the flowmeter. The flowmeter sits just in front of the inlet valve and is attached via a hose, and off to the left of the CCU. Part link to the flow meter==> http://www.repairclinic.com/PartDetail/Flowmeter/1381535?modelNumber=GHW9250MW2
If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems.
Read more: Whirlpool Duet / Kenmore HE3/4 Washer: F11 and FH Fault Codes ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2006/04/09/whirlpool-duet-kenmore-he34-washer-f11-and-fh-fault-codes/#ixzz1GVNXRInv
Get appliance parts at http://parts.fixitnow.com
Mar 13, 2011 | Washing Machines
My front loader is saying error FH ? Do you know
Here's the FH troubleshooting guide
or check out link go to this
http://www.repairclinic.com/0078.asp
WHIRLPOOL
Duet & Duet HT Failure
Code
Condition Check/Repair F/H No water detected entering machine or Pressure switch trip not detected.
Or
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Mar 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 02, 2009 | Washing Machines
Whirlpool duet FH code
its possible you have the correct number, but yes the FH is a "no waterdetected" fault, are you sure you rehooked all wires in the rightt location and in the right position(it possible to put a harnes sin the wrong slot or even upside down, the only 2 CCU's out there for this model and of you had the wrong one you would get wrong cycle selections, not anything to do with the intake waster, i would really recheck your connections
Jan 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F/H code continues
u have to go with a good technision
Aug 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
280 people viewed this question
Top Washing Machines Experts
