Question about Motorola Mobility RAZR V3i Cellular Phone
I tunes I was copied songs in "i tunes" folder,then i installed SD card in my "Motorola V3i" phone.But,in i tunes icon,no songs in playlist.Why,Sir?What is the reason of this problem in "i tunes"?
I am not understand it
Posted on Aug 20, 2008
How do i send song from the computer to the phone.
he Motorola razr v3i supports two kinds of music file formats: MP3 formats with bitrates of 192 Kbps and AAC formats with bitrates of 128 Kbps. Songs with lower bitrates are converted into appropriate bit rate songs before playing on the phone.
  1. The iTunes application should be open on the computer
  2. The phone should be connected to the computer using the USB cable such that the phone icon pops up in the iTunes application in the computer
  3. Select PREFERENCES from the EDIT menu in the application
  4. IN the PREFERENCE window, choose the PHONE option
  5. Before transferring the songs, choose the option which allows for conversion of all higher bitrate songs into bitrates of 192 Kbps
  6. Finally click OK to convert all songs into compatible formats ready for transfer
  7. Now the songs are ready to be transferred from the desktop to the mobile phone
  8. The songs can be transferred on to an external storage device like a memory card
  9. First the card should be installed on the phone
  10. Now the card should be set as the default USB connection on the phone. This can be done by going into the DEFAULT CONNECTION menu of USB settings in the CONNECTIONS menu
  11. The phone should be connected to the computer using the USB cable and the iTunes application should be open on the computer
  12. The application will show the phone icon on the left side of the screen
  13. Now drag and drop an entire playlist or specific songs from the playlist onto the phone. The average transfer time for a song is 45 seconds
  14. After all song transfers are done, the phone can be ejected by selecting the EJECT icon in the application
  15. The phone should be ejected only after the DO NOT DISCONNECT message disappears from the screen of the phone
  16. Now the songs appear in the iTunes digital jukebox on the phone where songs are stored under SONGS menu and playlists under the PLAYLIST menu
  17. Please note that the Bluetooth connection cannot be used to transfer music between the phone and the computer
Jun 24, 2011 | Motorola Mobility RAZR V3i Cellular Phone
At what site i can download free themes for my
You can themes at:
www.mobileheart.com/...themes/819-Motorola-RAZR-V3i-Themes.aspx
gallery.mobile9.com/c/motorola-razr+v3i-themes_289/1/
www.ownskin.com/theme
The best way to transfer song is to connect your mobile with the PC and use the connection type as mass storage and then you can simply transfer data as you do in a usb flash drive.
Apr 08, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Cant transfer mp3 songs to phone from pc
If you have a SD card in the phone, go into settings and set USB as DATA mode not modem and you can drag and drop the files on the SD card as if it is a jump drive.
Mar 14, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Sandisk Micro SD Card stops after 108 songs
If you formatted the card first, you should have had a true value of the Size.
Even a true 1 Gig card, only has a capacity of 960mb.
As the card has to allow for a valid boot-block to be written to it.
This is so the read/write device, can recognise the drive/cards format i.e FAT/FAT 32 et,c.
I,d suggest that you have a 512mb card, that has a 1 gig sticker on it.
The chinese have a way of doing this with MP4 Players. they sell them as 4 gig, when you format them, they,re actually 1 gig or smaller sometimes.
I,d suggest backing up yhe card, and formatting it, to see it,s true size. And that your also using the correct Format.
Mike @ compurepair.
Mar 14, 2008 | Electronics - Others
About itunes in motorola v3i
I have the phone to put music into itunes you need to go to settings then connection settings then USB settings after that you put default connection:Memory Card but you must first buy a 1GB micro memory card the V3i isn't strong enough to hold 2GB or more now when you connect it a message should appear saying from itunes on your phone so then itunes will open up on your PC and just start to drag and drop your songs to the phone and before you dissconnect the phone turn it OFF! or else the memory card will corrupt so make sure the phone is completly OFF! make sure you also install Motorola Phone Tools for other enjoyment in your motorola phone! Thats it
Feb 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Can see music on memory card
A few suggestions (Not in any particular order)
Format the SD card in the PC, Make sure the songs are in MP3 format, (In XP use windows audio converter to change if needed), make sure the MP3 files have a bit rate of 128 kbps or less. Make sure the phone is set to 'data connection' not 'memory
card connection' because the phone cant see the files, connect the SD memory card to the PC, use 'my computer' to view folders, you should have an 'audio folder' if your MP3's are contained in folders try removing each MP3 file from its folder and place directly into audio folder (cut & paste) delete the empty folders, you can organise any playlist's on the phone. If possible download WMP11 & Moto multimedia Plug-in, (makes loading a bit easier). Chris
Jan 10, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Getting songs on my v3i from computer
if u want songs on ur itunes then u need itunes software.......
othrwise u hv the folder named " AUDIO" jus copy and paste the song u want in that folder and u can find it on ur memory card....
Dec 25, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Storage of songs on v3i
dear sir i just want to know ,
how i can install itune in cellphone....
regards
rishi
Dec 17, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
62 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
