Have you fixed it or gotten rid of it yet? Because if not, I have a solution for you. I had the exact same problem and TV as you, and I fixed mine by leaning it forward. I think there may be a leveling safety feature for the screen, and it gets out of wack. So maybe try leaning it back and forward until you find the sweet spot.
olevia flat screen just went out one day......turns on and displays the ''olevia'' logo screen,,,,...
(More)
olevia flat screen just went out one day......turns on and displays the ''olevia'' logo screen,,,, but no sound, picture, cant get to menu from remote or t.v. what could be the problem? Not even a year old.
I am looking at buying a 2nd hand Phillips LCD tv 42' Model number 42PFL7532D/79 It still has a 2...
(More)
I am looking at buying a 2nd hand Phillips LCD tv 42' Model number 42PFL7532D/79 It still has a 2 yr warranty. Have there been any problems with this model?? Is there anything I should ask particularly before purchasing?
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent...
(More)
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent problems with the HDMI audio bleeding in to the other inputs. Sometimes if for instance I turned on the PC, I could hear the audio from the HDMI output on the satellite receiver through the TV speakers. Other times, I might just hear a crackle in the audio when in PC mode. If I switched back and forth between HDMI and PC inputs a couple of times, both issues would go away. I tell this just as background to what happened next. Since I have my PC hooked to the VGA input on the TV, I have been forced to manually switch the HDMI input from the Satellite receiver to my XBOX 360. (Sorry, I was too cheap to buy the $100 switch). Anyway, I usuall make this switch hot (TV on, Satellite receiver on, but XBOX off. This system although a pain, was working until yesterday. I was watching HD satellite, when I decided to play XBOX. I switched the HDMI cable, but when I turned the XBOX on, it wouldn't start up. I immediately assumed my XBOX had crapped out , but when I switche the HDMI cable back to the satellite, the TV would not recognize the signal. I have since tried the XBOX and satellite on another tv with HDMI, and both still work fine. I am thinking that some sort of switch in the tv has gone out, but I don't know. Should I just junk this TV for a new 1080P? My problem with doing that is that I use PIP with the PC on one side, and HDMI on the other. This tv does that, but I can't find another tv that does.
