Question about NEC Office Equipment & Supplies
MESSAGE NO LOOP CONNECTION - NEC Office Equipment & Supplies
    Genius:
  • 2,120 Answers
You do not have a dial tone.
Posted on Aug 31, 2008
How can you tell if the protection wire loop is bad?
Your protection circuits are usually wired in series so that if any one of them is open, current will not go to the starter and ignition circuits.
U seem to know what you are doing so just bypass the loop and see what happens. If item starts then that loop circuit is defective. If it still does not run then your issue is elsewhere.
Oct 06, 2015 | Garden
My HP laptop lost power (not because of its fault) and now I can not aquire an IP address via either of my wireless cards or the RJ45. Comand prompt inquiry shows 0.0.0... and ipconfig/renew gives an error...
Try theses options: ( turn off and on the power of your router / restart your laptop ) - to refresh all. See also if other computer and laptop can connect to the internet thru the same router just to isolate.
1. use your wired connection first ( rj45 ). Unplug and replug both ends of the cable from the router and from your laptop. Restart your computer. Then check if its ok.
2. Try to do a loop back test to check if your network card and the tcp/ip is working properly. To do a loop back test, go to command prompt and just type " ping 127.0.0.1 " and press enter. It should reply and should tell you 0% loss. If there's an error then disable and enable your LAN ( Local Area Connection ).
3. Do " flush dns". Go to command prompt again, then type " ipconfig /flushdns" then press enter.
Nov 13, 2010 | Computers & Internet
How do I connect an external AM antenna
G'Day
The AM loop antenna needs to connect between the terminals marked as "AM ANT" and "GND" on the rear top right corner of the amp. This is the normal configuration for a loop antenna. The other option(not using a loop antenna) is to connect "GND" with a single insulated wire to a decent earth connection (2 m copper stake hammered into the ground or a water pipe, and a single wire elevated as long and as high as you can. this style of antenna system is not generally used these days, as the transmission power of radio stations has increased greatly over the years so that a small loop antenna will do the job So, most stations should be tunable with just the loop, remember however, that it will be directional. If the loop is in proximity to other electronic gear, it may not perform as well. Keep it as far away from the rest of your gear as you can.
You will generally get no AM stations AT ALL until you have connected the loop to both terminals. Happy to talk to you further about this. Please rate my solution. Cheers
regards robotek
Apr 08, 2010 | Yamaha HTR-6130 Receiver
I got this message lnb short ,what can i do ?
Start at any outside exposed connection of your Sat cables. They get water in them in the bad weather. The "Barrel" F connector then needs changing and dry out the mates. Sloppy installers do not put in "Rain Loops" (a loop below the connection so water runs down to loop to drip instead of runing into the connection), rubber boots, or Silicon protective coatings at the connections. 4 way Diseqc supplied with STB should have caps on the unused ports to keep moisture out. Good luck.
Dec 16, 2009 | Humax HFA100 DTV Receiver
On booting up error message hard drive or dvd not connected run repair cycle, this just runs in a loop, lap top had a knock but not severe was ok for a couple of days then problem started
Take the computer to a qualified connection.
Disassembling a laptop is *NOT* a job for the end-user.
Either the "knock" loosened some cables, or it damaged the disk-drive.
Nov 20, 2009 | Toshiba Satellite P200-0TD00Y Notebook
I have the 600-water Malibu transformer. Some nights one of the loops of lights will go out. The other loop stays lit. I might go out 30 minutes later and both loops are lit. I am still well under the...
Check for a loose connection where the problem "loop" connects at the tranformer.
Also, swap the "loop" connections to the tranformer. If the problem still persists replace the wire run. Sometimes wire gets damaged internally and visual inspection will not reveal that.
If the problem occurs in the other loop after the swap, then you probably have a bad connection inside the transformer. If that is the case, you won't be able to use that connection as the transformer has no user servicable parts.
Also, if the tranformer in under 5 years old, it's still under warranty.
Jul 06, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Printing syntax
'declare the variables
Dim Connection
Dim ConnString
Dim Recordset
Dim SQL
'define the connection string, specify database driver
ConnString="DRIVER={SQL Server};SERVER=yourServername;UID=yourUsername;" & _
"PWD=yourPassword;DATABASE=yourDatabasename"
'declare the SQL statement that will query the database
SQL = "SELECT * FROM TABLE_NAME"
'create an instance of the ADO connection and recordset objects
Set Connection = Server.CreateObject("ADODB.Connection")
Set Recordset = Server.CreateObject("ADODB.Recordset")
'Open the connection to the database
Connection.Open ConnString
'Open the recordset object executing the SQL statement and return records
Recordset.Open SQL,Connection
'first of all determine whether there are any records
If Recordset.EOF Then
Response.Write("No records returned.")
Else
'if there are records then loop through the fields
Do While NOT Recordset.Eof
Response.write Recordset("FIRST_FIELD_NAME")
Response.write Recordset("SECOND_FIELD_NAME")
Response.write Recordset("THIRD_FIELD_NAME")
Response.write "<br>"
Recordset.MoveNext
Loop
End If
'close the connection and recordset objects to free up resources
Recordset.Close
Set Recordset=nothing
Connection.Close
Set Connection=nothing
May 16, 2009 | Microsoft Windows Vista Ultimate Edition
Nokia phone having an error loop when pairing with Acura bluetoot
it means your media player has a bluetooth connection that must be addressed, it sounds like you have accidentely 'paired' it to the music player instead of the bluetooth device.
May 05, 2009 | Nokia 6300 Cellular Phone
No loop connection?????
Use a regular telephone do you get a dial tone?
May 04, 2009 | Office Equipment & Supplies
Error message -no loop current
It can't find a DIAL TONE check the line with a regular phone.
Mar 06, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
