Question about Alpine CDA-9855 CD Player
Alpine cda9855R Hi there i need to replace the actual head unit but just the back as ive fried it front is fine where can i get 1 and how much please thanks
I have the back bit i messed up the face sure we can work sumin out
Posted on Dec 02, 2008
  • 3 Answers
R u willing to sell urs for parts
Posted on Nov 04, 2008
  • 81 Answers
A new one will come with a new face plate, but you could try checking pawn shops for a used one. Prices will vary.
Posted on Sep 02, 2008
Alpine 9845 cde head unit car stereo i Cannot figure out how to access the Fader not the balance,altho i havent seen that function either. ive been to the alpine site and they dont even mention it. im sure...
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
Feb 11, 2010 | Alpine CDE-9845 CD Player
Head unit connect
You will only be able to use this EQ on the front or the rear speakers. You will have to get another EQ if you think you need one. Usually, the front speakers of a car's audio system are the smallest and the rears are larger. You really do not want an EQ on the subs. If it was mine, I would hook the EQ between the head unit and the rear speakers. If you feel this does not sound right, you may need, but I doubt it very much, to get another EQ for the front speakers. Good Luck
Aug 18, 2007 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Bought a Alpine PDX1.1000. 1 - 8v issue
Hello rsnyder_223,
As long as the gain is adjusted properly for the input, there should be no problems with the amp.
The head unit preamp output is probably a little low or there is too much voltage drop on the RCA's. It doesn't take much of a drop when you are working with such a low level to begin with. That's one reason that Alpine gives you the option to select an input level.
It's also possible that the input sensitivity of the Alpine is slightly high. Electronic components usually have a nominal value and their actual value can range up to 20% from that nominal. But again, you have a gain adjustment to insure that the amp is not overdriven. Make sure that it's set so there's no distortion and you should be OK.
Hope this helps.
Aug 23, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
CDA-9813 No sound, will not eject CD
There is a very tiny dot located either on the actual face of the alpine head unit or on the front plate of the radio once the face has been removed. Once you find this dot(if on the actual face) you need to make sure unit has power turned on and witha tiny needle or pick you may push this reset buton in for about 2 seconds. The face will automaticaly fold down and the disk will eject itself. Once this is done do not place the same disk back into the unit. Hope this solves your problem
Jun 09, 2009 | Alpine CDA-9813 CD Player
No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Dec 12, 2008 | Alpine CDA-9855 CD Player
Alpine CDA-9813 CD Player problem keeping the power stay on
i have that same problem. when i turn the volume up, it shuts off but comes back on right away. the only thing i can think of is i'm not running the constant power directly from the positive terminal on the battery (which is what is recommended). not sure if thats the solution but im gonna try and wire it right anyway...
May 18, 2008 | Alpine CDA-9813 CD Player
Alpine head unit CDA-9855R
Yes, I'm sure Alpine will sell you another face but there is still the option of repairing the broken face at a good repair shop. Of course getting a new face is the easiest (read most expensive) way to get you going again.
Jun 08, 2007 | Alpine CDA-9855 CD Player
Alpine CDA-9855 CD Player Logo
94 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
