Question about Foxconn 661M03-G-6EL Motherboard
Can not get on line
Tried to get online and failed. Cable modum hard wired to fast ethernet port. Went to divice manager and there is a yellow box with an ! point in it over the sis900 fast ethernet line. Tried to up date drivers with foxxconn dics, still no good. bought driver detective and ran program and it stated drivers are good. What should I do buy an ethernet card? If so any recomendations ? Thanks Andy
  • Andrew D. Paris Aug 20, 2008
    Tried the last suggestion to no avail. Finally bought a fast ethernet card and this worked good. After I got on line again I downloded the correct drivers and these still did not take. After I downloded them and tried to update them with device manager It stopped mid stream and said can not turn on divice (code 10)!?
  • 3,051 Answers
Have you uninstalled it from device manager and then rebooted the computer the new hardware found should pop up on the taskbar and do the rest of the installation there and if it needs the disk then insert the disk and go from there
Posted on Aug 20, 2008
Why does my Roku box not detect an ethernet connection after 6 years hard-wired?
Its better to access the Roku secret screen for you to check if the Wired MAC address is still showing, because if it is all zeroes and not alpha numeric, it means its a defective ethernet port. To do this start from the home page. Then using the Roku remote press the home button 5 times, fast forward 3 times, rewind 2 times. On the upper left side look for Ethernet or Wired MAC, it should show alpha numeric.
Aug 26, 2014 | Televison & Video
Pls.. help me my device manager they have yellow question mark.NETWORK ADAPTOR ?via rhine 11 fast ethernet adapter OTHER DIVICES ?multimedia audio cotroller ?pci simple communication controller ..pls help...
You can remove these all these error by installing all these driver's through the CD you must have got with the computer. Or you can download it from the internet for the specific model you are using. There are no driver's install on your computer that's why there are such error on the device manager.
Apr 26, 2011 | Computers & Internet
I have a Compaq Presario SR1630NX and I cannot connect to the internet. When I plug the Ethernet cable into the back of the machine, the port does not light up. Is that normal, or is the port bad? Please...
Not normal. Try plugging in a friend's laptop to check out the cable and network. If that machine goes online, your port may not be configured or the ethernet card has failed. Device manager in Control Panel canel give some diagnostics and can check for new drivers.
Mar 19, 2011 | HP Compaq Presario SR1630NX PC Desktop
Wireless will not work light stays amber color Using cabledsl now. Wireless came on once when using cable dsl . So I removed cable and was able to surf. I shut down for night and put on next day -just...
Presario V6210US Notebook
wifi is complex. unlike simple wired Ethernet.
why not use wired first.
why jump the gun and guess, and pick the most hard and expensive fix first. when you car misfires do you replace the engine,first?
no.
what wireless card..? on modern PC its hidden inside.
on super old PC LT its a PCMCIA card plug in
on others its a USB dongle. (there did all 3 for you)
what OS.???????????is this XP?
what router (wifi do you have?) (the box with antennas")
The router makes the DLS connection with a pass word
do all other wireless device
is Verizon your DSL service provider, really? mines ATT. land line + DSL, my line is cut in half now, for ever. (never again ATT me)
but we do not know what you have there.
nor how far the notebook is from said (unsaid) router.
the real problem here is the now RETIRED PC notebook
HP does not support it now, so getting drivers is hard.
proof of that.
https://support.hp.com/us-en/retired-products
here is a short check list and HPs
1: can others PC connect in your home to wifi. or from CELL?
that must be done first, to see if A: its router issues. or B: your PC.
using your wifi login credentials.
2: we make it to B its your PC for sure.
then read your manual called trouble shooting
id go to device manager first see if the wife card is there , and ok.
your wifi card is mini-pci card inside mounted to the MOBO.
first connect a CAT 5/6 cable from the ethernet port of your PC
to the router,
do you now get , internet connected, if yes good, if not the router may be configured wrong.
if yes, good
we now go to device manager, and look for the wifi module
if the module is there in DM. right click and and lit windows
plug and play find your driver. this way, using the ethernet cable.
see? (to get drivers takes a connection and ethernet is the joy of life here)
ethernet is wired connected.
if ethernet fails we work far more hard, lacking any connections
or a working PC .
again, no OS stated, is this the stinky XP? the viruse magnet.
your CARD. I bet its not bad !
v6000 mobo red arrow is ethernet. jack
v6000-ooptjg14f2uaokq3pusqdg3g-1-1.jpg if your OS is not dead, and has all the origional HP drivers
all loaded an not lost. then this magical port just works
you plug in the CAT5 cable and bam, connected. in seconds.
this is always the best way to fix computers at home.
get this wire working first, and now that you have internet working
you can do vastly more things even fix WIFI.
Aug 03, 2017 | HP Compaq Presario V6210US Notebook
Broken wires copper wires in the ethernet port on xbox 360
make your brother fix it or you will break something of his!!! :)
Jul 03, 2009 | Microsoft Xbox 360 Console
Can usb substitute for the ethernet connection?
Perhaps buy one on eBay (possibly $60) and pull it's interface circuit board, to replace your bad one:
http://search.ebay.com/netdisk
Apr 10, 2008 | Ximeta NetDisk (NOWWL) 160 GB Hard Drive
Can not get on line
1. Make sure the ethernet cable going from the modem is going into the port on the router labeled "internet." Next, make sure the ethernet cable that is plugged into your desktop is going into the port labeled either 1,2,3,or4.
2. If it is in port 1, or any other port, make sure you try all of the number ports.(1,2,3,4)
Apr 02, 2008 | Computers & Internet
Westell 6100 seems unstable
if the ethernet ligth on modem is off, pc is not talking to the modem
check ethernet cable connection,, make sure it is properly and firmly plugged into the correct port...if still the same check network interface card,, right click my computer then click properties goto hardware tab,, click device manager button,, look for network adapters...right click adpter installed on pc then click update driver
Feb 22, 2008 | Westell Wirespeed LiteLine 6100...
Foxconn 661M03-G-6EL Motherboard Logo
149 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
