I'm trying to open a Benq Joybook 8000 laptop, to replace the hard drive. There seems to be an extra screw inside holding the two halves together. I've tried removing the keyboard, but it appears to be underneath the memory. Would you know how to open it in a way that it can be put back together again? :-) Thanks
Open it with screw drwier
Posted on Aug 19, 2008
SOURCE:
Show me how the HD placed
Are you asking where the hard drive is located?
If so, remove the power cord, turn the laptop over and remove the battery, then look for a covering that will probably have 3 or 4 circular discs on it. Remove the screws from the cover and the hard drive will be inside the bay. Remove the screws if any that holds the hard drive in the bay then slide it back to pull it out. Once you have the hard drive out, it might be inside a caddy and secured with 4 screws.
If the hard drive is not located on the bottom of your laptop, then it is under the keyboard or plamrest which means you'll have to take them apart to get to it.
Jun 04, 2012 | BenQ Joybook 3000 Notebook
I need vga drive benq joybook A53
Take a look on this page.
http://notebook.driversdown.com/notebook-drivers/BenQ-Joybook-Display-Driver_125511.shtml
Or have a web search for:
BenQ Joybook A53 Chipset & Display Driver V6.24.10.3820 for Windows XP
Aug 23, 2010 | BenQ Joybook A53 Notebook
My benq joybook r45 won't boot. the battery is fine.. the screen will go brighter/dimmer.. and attaching an lcd doesn't work.. what is wrong with this machine?
a number of things could be wrong- bad ram, bad motherboard. a bad hard drive will still usually get you a post screen. if you are at least getting a post screen, i would look towards hard drive issues.
Oct 31, 2009 | BenQ Joybook R45 - R45-PE-16, Intel Core...
How to open the disk drive??
Do you use a mac or p.c.?
Ok....
shut down the system and restart
If the door still will not open you probably will need to open up your computer and disconnect the power to the drive -
gently pry open the drive door and check for obstructions
If it is an obstruction it probably had a cd/dvd it it for a really long time and they get hot and spin at very high RPMs and tend to bust the CD/DVD into pieces.
and last the drive is getting old - replace it. Thanks
Aug 17, 2009 | BenQ Joybook 8000 Notebook
My benq joybook says that one of the files is missing
You have corrupt system files on the hard drive which is why your getting that message. Try to go into safe mode. If you can get into safe mode, do a system restore back to the last date that the machine was working properly. If you can't get into safe mode then you'll need to wipe out the hard drive and restore it back to factory defaults. If you need help doing that, let me know and I'll be happy to help you further.
Jun 10, 2009 | BenQ Joybook 5000U Notebook
Replacement of HD of BenQ Joybook 3000 PC Notebook
Here is the manual. I hope it helps
http://service.benq.com.hk/HKUploadFile/Book/Joybook3000(3000MU)M.pdf
G'luck
Oct 23, 2008 | BenQ Joybook 3000 Notebook
Hard Drive Replacement on Notebook
your computer might not able to support this capacity i suggest calling the manufacturer for Hardware compatibility, if it does not recognize, then the bios might not be able to recognize this big capacity, updating to higher version of bios might help but sometimes not, it all depends on your motherboard config.
Sep 17, 2008 | BenQ Joybook 5100U Notebook
FAX componet of Windows
How to enable and configure the Fax service in Windows XP Install the Fax component By default, the Fax component is not installed during Windows Setup. To install the Fax component, follow these steps
Good Luck, Please dont for get to Vote.Thank You.
Dec 15, 2007 | BenQ Joybook 8000 Notebook
Reboot disc
is there a floppy drive on you computer
Oct 13, 2007 | BenQ Joybook 5100U Notebook
Trying to open up joybook 8100
If you look very carefully at the top of the keyboard in the recess there are 3 tabs that can be pushed back towards the screen with a knife blade and you can lift the top of the keyboard out and remove it. You will then find 3 silver screws that hold the top to the bottom. Three cables need to be removed from their sockets and the cables that connect to the network card (a black and a grey wire) the connectors just pull off. Use a small screwdriver to prise them up gently. Voila the laptop is now in two pieces.
Dec 14, 2006 | BenQ Joybook 8100 Notebook
Computers & Internet Logo
54 people viewed this question
Ekse
Alun Cox
