Question about KitchenAid KCM511 Coffee Maker
Err nessage 2
Coffee makerdoes not work. err2 message displays. Not able to correct the problem
  • 231 Answers
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinager. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinager and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Posted on Dec 27, 2008
SOURCE:
Err2 on display of coffee maker
Check your manual for instructions on the display codes.
Mar 25, 2014 | KitchenAid Coffee Makers & Espresso...
I followed the instructions you gave me for the ERR2 problem.. but still not working.
I have a coffe maker that is 1 week old, the model number is w10321647a, it is a cusinart make and I am unable to make coffee when I press the Brew buttion, I get an error message that is err2. I have unplugged the coffee and plugged it in a again and it is still coming up with err2 and no coffee. Please help!!
Jan 27, 2011 | KitchenAid KCM511 Coffee Maker
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Any problems w/ Kitchenaid coffee maker 511?
Nothing but problems! Spills,messes caused from poor engineering/design Finally a err2 message means the element is probably bad. Called kitchenaid and because ir is just beyond warranty repair they did offer a discount on a new one. I said No Thanks,I would not own another one.
Dec 22, 2009 | KitchenAid KCM511 Coffee Maker
Error 2-Unit will not heat or brew. Stopped in middle of brewing cycle and flashed error 3 code. After unplugging unie and plugging back in an error 2 remains.
Error message 2 is a result of the water heating element burning out. The element is replaceable, if you can find a vendor who sells the element assembly. Price of a new element may be more that a new pot though, if you're lucky enough to find a parts vendor that sells one.
Dec 18, 2009 | KitchenAid KCM511 Coffee Maker
My Survival Guide To The Dreaded Err2 Disaster
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Thank you, have a nice day.
Aug 30, 2009 | KitchenAid KCM511 Coffee Maker
Kitchen Aid coffee maker err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears. This may take a few seconds.
Apr 07, 2009 | KitchenAid KCM511 Coffee Maker
Kitchenaid coffee maker model #KCM534OBO
Err2 is a failed heating element. There is no fix or replacement parts sold. I was lucky I had a receipt, even out of the year warranty they(KitchenAid) are still replacing it.
Nov 07, 2008 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
KitchenAid KCM511 Coffee Maker Logo
147 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
graybeard32301
Ismael Rodriguez...
Steve Allison
Steve Allison
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
