Question about Datamax DMX-I-4212 Label Printer
Thermal Ribbon has a wrinkle
The Thermal ribbon has a wrinkle in it and it's causing blank spots on the label. The ribbon roll has been replaced and the tension has been adjusted neither have made a difference. What else can I try?
    Scholar:
  • 87 Answers
The thermal print head is damaged. You can try to clean it with a thermal printer head cleaner. That will only help if it is just clogged up with thermal print ink.
Posted on Nov 22, 2008
I keep getting wrinkled ribbon in my zebra XiIII printers Part seems to be caused by static, the ribbon will not rewind properly
Its probably not static. 1. Wipe the print head and platen roller with alcohol dampened qtip or lint free cloth. Print about 30 labels while gently pressing on the ribbon supply, causing it to drag a little and observe if the wrinkles stop. If so tighten the nut on the end of the ribbon supply a little at a time until wrinkles disappear. Check the head pressure toggles on top of the print head and make sure they are adjusted about the same. If you have been printing a lot of the same size labels, check the platen roller (white) at the point where the right edge of the label rides on it for a slight offset where the roller is worn down. If it is worn, the only fix is to replace the platen roller.
Feb 17, 2011 | Zebra Xi Series 170XiIII Thermal Label...
My zebra id card printer p120i does not print very sharp
zebra p120i TROUBLESHOOTING LINK
Printing shows blurry printed image.
Possible Cause:
•Ribbon cartridge may not be correctly positioned.
Solution:
•Check that the ribbon is properly rolled onto the ribbon cores of the cartridge, with no wrinkles.
•Replace ribbon cartridge, making sure it locks in place, and print again.
Possible Cause:
•Ribbon may not be synchronized on the correct color panel position.
Solution:
•Open lid, then close lid to synchronize ribbon.
Possible Cause:
•Cards may not meet specifications.
Solution:
•Use a different supply of cards.
Possible Cause:
•Dust or embedded contamination inside the printer and/or dirty Cleaning Roller.
Solution:
•Clean the Print Head.
•Replace Cleaning Roller
Jan 30, 2011 | Zebra P120i Thermal Card Printer
Zebra 105SL thermal Label Printer prints blank with new supplies
Some possible reasons:
1. The darkness is not set high enough for the paper/ribbon combination
2. The ribbon is on backwards. Zebra uses coated-side out ribbons so the ribbon should be coming off the right side of the roll if you're looking at it from the side.
Hope that helps !
Apr 16, 2010 | Zebra 105SL Thermal Label Printer
Constant wrinkle in the print. tried different
Usually a ribbon wrinkle is caused by an imbalance across the printhead. There is more pressure on one side of the ribbon then the other (if using a ribbon across the whole web). Check the printhead pressure adjustment dials located on top of the printhead. One side may be "down" more then the other.
Hope that helps !
Apr 05, 2010 | Zebra S4M Thermal Label Printer
HI,when I print , the printer do some label , after go in pause mode automatically message=" = continue = reprint" but after 1o label , the printer give a second error "out of ribbon" .Can you help me...
Hello
After many efforts I have found that in the new PX6i models, the "transfer ribbon mechanism" (the wheel that is responsible for making the ribbon roll) appears to be defective. What happens is that when rolling back in order to keep the ribbon stretched, instead of stopping at the fixed point, it continues to roll back a bit. After a few prints, this causes an "out of ribbon" error.
The solution: replace this part with a VALID part (a new one).
Pavel
Feb 08, 2010 | Intermec EasyCoder PX6i Thermal Label...
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
Ribbon wrinkle
Its a bit of both. Too much pressure on the printhead can cause this as well as a poorly aligned ribbon. Adjust both then adjust the darkness the same as you would position or calibration
Jul 09, 2009 | Zebra 105Se Thermal Printer
Printer Ribbon has a wrinkle in it
Remove the ribbon and try to remove the crease. Check the printhead for obstructions. You may have to open up both halves of the ribbon cartridge to look for jams or obstructions.
Aug 19, 2008 | Datamax DMX-I-4212 Label Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Ribbon wrinkles when printing barcodes
This is usually caused by temperature of the thermal print head. This is found in the printing preferences of the printer.
May 22, 2008 | Zebra Z4Mplus Label Printer
Datamax DMX-I-4212 Label Printer Logo
566 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
