Question about Dell A940 All-In-One InkJet Printer
PRINTER WONT PRINT
I AM NOT PRINTER INCLINED SO I DO NOT KNOW HOW TO CORRECTLY TELL IN A TECHNICAL WAY-JUST WHAT THE PROBLEM IS OTHER THEN TO SAY THAT THE DELL PRINTER WILL NOT PRINT. THERE IS INK SO THATS NOT THE PROBLEM-I JUST RECENTLY DOWNLOADED A DRIVER AN I AUTOMATICALLY ASSUMED THAT ALL FUNCTIONS WOULD WORK AN AS FAR AS I CAN TELL ALL OTHER FUNCTIONS DO PLEASE HELP THANKS A MILLION CJ4023ZXV
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Well..let's see...does it run a test page?
Posted on Aug 19, 2008
Error (2)
Please tell about your printer model & brand.
Jun 12, 2013 | Office Equipment & Supplies
I cannot get the envelope fuction to work correctly. The printer tells me I have a paper jam, when in fact I am trying to print an envelope
The printer will stop printing is there is an error, check for any paper jam before printing. Take note of the error message and locate the exact jam.
Use the manual feeder when printing on envelopes. You may click on the link http://bit.ly/rnHp5b to see instructions on how to go about the procedure using the manual feeder.
For further assistance, please call Lexmark Technical Support.
Mar 08, 2011 | Lexmark C532n Color Laser Printer
My z35 printer wont print. It is on and wired correctly but when I push print nothing happens. i have enough ink
Try to check if you have Print jobs stucked in the queue and if you do have just delete them first and try to print. Also, you can try to disconnect the printer from the power by disconnecting the black box at the back of the printer where the power is attached. Wait for 20 seconds and connect back the power brick. If the printer doesn't turn on automatically you can press the power button. Then you can try to print again if the printer is ready. If still the same I would suggest contacting Lexmark Technical Support. Thanks.
Aug 12, 2010 | Lexmark Color Z35 InkJet
My printer says load paper then press start, I have paper in there and it wont print.
Dont know what you have already tried but first off verify that you are loading paper to the correct tray. Now this tray is going to have a switch located toward the feeder that tells the printer paper is loaded make sure the paper is back far enough but not to the point where you are forcing the paper into the feeder. If all this still doesnt work try reseting the printer and printing a test page. Hope this helps.
Mar 10, 2010 | Dell 924 All-in-One InkJet Printer
Maintenance warning/technical issue message stops printing
You just need to reset your printer. Google search a resetter program for your printer model.
Jan 10, 2010 | Epson Office Equipment & Supplies
Windows 7 and Linksys wireless print server
Step for installing Network print server in windows 7.
Click Windows "Start button"
Select "Devices and Printers"
Click "Add a Printer" button
Select "Add a Network, Wireless or Bluetooth Printer"
Printer wizard will searhc for all network printer including wireless.
Select "The printer that i want is not listed"
Select "Select a shared printer by name"   (Make sure you have shared the printer you want to connect)
Type the IP address of the printer if it ia a printer.
If it is printer that is connected to a PC then type like this below
\192.168.0.50printer shared name where 192.168.0.50 is the IP address of the PC where the printer is connected.
Click Next and if you want to Send a test print you can try that too,otherwise click "Finish".
That's it.
Jan 02, 2010 | Dell Inspiron 1545 Notebook
Do I really need a new print head - or should I buy a new printer?
i believe the printer u are using is a bit old,,the head is worn out and its natural..every hardware equipment has a eol{end of life},,u can print but the quality of the print will deteriorate with time..
i dnt know the model no,, but i think it wont be wise to buy a print head than buy a new printer,,reasons
1.new printers are really chaper than old ones and the price ratio of buying a new printer wud b better than changing the head
2.if even u buy the printer head it is complicated to install it and if correct allignment is not achieved on the plane head then the whole printer is useless
my advice:use the old printer till u get a satisfactory printout,,then buy a new printer
best of luck,,keep me posted,,giva good rating
May 19, 2009 | Office Equipment & Supplies
Dell 924 dell printer head ;error 1203;change cartri... sane problem.help|| black will print but color wont print' correct cartridge is inserted ,still color wont print. warning was ignore that ink was low
Hey do a power drain by removing all the cables from the rear of the printer and then hold the power button on the printer of 15-20seconds with all the cable out connecting the printer... Then power on the printer if you still see the error code message displayed on the printer display screen do a nozzle clean in the computer, check on if the printer prints the nozzle clean test page perfectly.If not remove the cartridges and clean the nozzle of the cartridges with a clean cloth and be careful so that you do not destroy the copper contacts, clean the same you see on the carrier(where you place on the cartridges). I think this should work.
If not call in technical support.
Regards,
Dev,
Printer Technician.
Feb 27, 2009 | Dell 924 All-in-One InkJet Printer
Printing blank
Likely the simplest way would be to return the machine to its factory defaults. That would ensure that whatever they had done to mess it up, would be un-done. The negative side to this, would be that you would lose all stored information such as phone numbers. To see how to do this, you would need to open your user manual to page B-7. If you do not have one handy, here is the link to the manual online:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000387/ALLFB_UsaEngUsr_B.pdf
Hope this helps.
Apr 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
Printer wont print
Service error may mean- ink overflow chamber needs attention Check Canon Technical Support or go to www.fixyourprinter.com
Jun 06, 2007 | Canon PIXMA iP2000 InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
seerads
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
