Question about Polaroid FLM-2632 Television
Poor reception when connected to cable (no cable box); DVD player will NOT accept discs
Recently moved 26" Polaroid TV from another home where it was configured to receive IPTV service. When connected to the cable, the picture is very fuzzy---like poor antenna recption. There is NO cable box. There are other televisions in the house which have good reception.
The built-in DVD player will NOT accept discs---feels "tight" when I try to inset them. When I try to operate from the remote, using INPUT, the DVD sign comes up in the corner, then TV shuts OFF within a few seconds?????????????
Model # TDA-02610C
I called Polaroid Customer Service.
Thanks
rosemary38
Posted on Aug 20, 2008
How to play dvd
If you are using the built-in DVD tray, press TV (in case you have a Cable Set-top box). Then press Input and navigate with the up/down keys to the line labeled DVD. Then press OK. Finally press play on the Polaroid TDA-03211C remote or on the side of the TV. The remote play button is in the center of the row below the row with skip reverse and skip forward buttons.
If you are using a different DVD player, press the input button and then the up/down arrows to get to the input for your DVD player. Then press the DVD button to control the DVD player.
If you are using a universal remote control, then you may need to program it to the TV and the DVD player separately. (Some universal remotes may only support the TV functions of this TV.) Make sure that your universal remote has an input button that works. You may need to try multiple codes for Polaroid TVs.
I hope this helps.
(note: the DVD must be correctly installed so that the printed side (label) is facing the front of the TV. If you do not get a response, try the disc in another DVD player. The DVD player laser tracking can fail without warning. If the disc plays in other units, this may be the problem.)
Mar 02, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
Hook up and programming
have you try to check the the video cable connections from the dvd to the tv..?
Jun 19, 2008 | Sanyo DVW-5000 DVD Player/VCR
I have a Polaroid 26"
It is a bad tuner, the tuner needs changed or the tuner module and that will take care of your problem.
Dec 22, 2010 | Polaroid FLM-2634B 26 in. LCD Television
I have a samsung42 inch flat screen and a dvd and a sky plus box and avhs recorder could show me how to do the set up connections please
If you have a blueray or HD DVD player I would connect using a gold plated HDMI cable from the TV to the DVD, make sure that you buy the correct HDMI version for your TV. If you don't have a HS DVD player recorder then use a HQ SCART as below.
Most SKY+ boxes still have a SCART connection I suggest that you buy a HQ gold plated ribbon connector to connect the SKY to one of your AV (audio visual) channels. The benefit of using SCART is that it will autoselect the AV channel when SKY is taken out of standby.
You will not need to connect using co-axial cables these are pretty much redundant now as you can get all your channels through your SKY dish.
Also if you live in a poor reception area and your TV has freeview built in SKY is your better option.
Nov 22, 2009 | Televison & Video
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
TV/DVD reception
The main aerial goes into the box then out of the box into the dvd then from the dvd into the tv,if the dvd is analog tuning the pic will not be as clear as the digital
Sep 28, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
My polaroid dvd player keeps reporting "Bad Disc" on discs that play just fine in other DVD players. What can I do to fix this problem?
Is the movie a copy or an original, some copies do not work in all machines, some will accept a dvd-R but will not work with a dvd+R except if you have a brand new unit, they usually accept most discs, the older dvd players are not compatable with all blank dvd's...Steve
Jun 13, 2009 | Polaroid PDM-8551
Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Jan 27, 2008 | Panasonic SC-HT680 System
Poor cable connection
radio shack sells type f/rca adaptors
Jun 28, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Polaroid FLM-2632 Television Logo
255 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
