Question about Motorola Mobility RAZR V3
Many problems the phone dials people by itself, when I try to call someone I get network failed, I am getting calls and the people tell me they didn't call me, it takes about 5 times before I can reach the person I'm calling
    Brigadier General:
  • 7,752 Answers
You should purchase a new phone or have the firmware reflash on the phone to correct these issues
Posted on Aug 20, 2008
You cant here the dialing ton when calling someone
Hi, when you try to call and you don't hear a dial tone,is because the ear piece that makes you hear some one calls you is damaged and will need to be replaced.
Usually gets damaged by itself and to replace the earpiece, you will need to disassemble the phone to be able to replace the hear piece.
The earpiece is located atthe top head of all phones. And is easily to locate.
When you replace the earpiece you cannowhear the dial tone on your phone.
Thanks for using fixya.,.
Jan 11, 2011 | Cell Phones
Tip
How to block a Cellphone number?
For privacy reasons, you may want to avoid people knowing what number you are calling from when placing a call from your cell phone. If you want to block your cell phone number from showing up on caller ID when you call someone, the process is very simple. You can block the number through your cellular phone carrier or temporarily on the phone itself..<br /><br />HERE IS THE INSTRUCTIONS :<br /><br /><br /><br /> 1 .Call your cell phone carrier. Dial 611 from your cell phone to reach customer service and tell your provider that you would like to request line block. The representative from your carrier may ask you a few questions, but the process is quick and painless.<br /><br /><br /> 2. Dial *82 if you need to unblock your number. Once you have put line block on your phone, you can temporarily take it off by dialing *82 before dialing out.<br /><br /><br /> 3..Block a specific call. If you do not want to put line block on your cell phone permanently, you can block your number temporarily on a call-by-call basis.<br /><br /><br /> 4..Dial *67 before dialing out to just block that particular call. After entering *67, proceed to dial the rest of the number as usual.<br /><br />
on Apr 10, 2011 | Cell Phones
When i flip the phone open, on the main screen at the top it says "No access to net." Whenever i try to make a call the call doesn't go through and is back to the main screen. And when someone calls me,...
Have you tried shutting the phone off for about 10 seconds then turning it back on? My phone does this some times and it's just because I am out of range of a tower for the network. If this doesn't help, it could be a network problem and for that you would have to contact your network provider.
Nov 04, 2009 | Sony Ericsson TM506 Cell Phone
Whenever I try to make a call the number is dialed and then call failed keeps being displayed
It is only a network problem.Please go to settings>network and scan for all available networks.Select your present network provider from the list and register it by pressing the right button.Now switch off the phone for about 15 to 30 minutes and restart it to make the calls.Thank you.
Oct 11, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Cannot dial out
likely a problem in the telephone company's lines or maybe a problem with your equipment. Call your service provider and ask them to test the line. They'll be able to tell you if it looks like there's an outside problem and if so they'll dispatch a repair technician to resolve it.
Aug 27, 2009 | Lands Phones
Telephone has a dial tone but cant dial out
talk with a technician about a problem phone line filter for the internet
it is possible that it has failed and the adsl and phone frequencies are giving a problem to the phone operation
Apr 21, 2017 | Vtech Lands Phones
How to create multiple users for one extension
we have the same sort of system in our own building but i wasnt aware there was a way of slpitting one line into two occpants, we use a software called LDC client which monitors the calls and saves a copy onto our voice recording server. there is a code to use on the acctual phone station itself which is usually *727ext1234 then dial. this will swap the current extension to the new one which you insert int the ext above.
Feb 13, 2009 | Panasonic (KX-TDA200)
When i pressing green Dialing key for making a call it fails to dial (Hangs), i hv to restart each time (6630)
HI HAROON
YOU SHOULD FORMAT YOUR MEMORY CARD AND CELL PHONE MEMORY AND TRY AGAIN.IF THE PROBLEM PERSIST THAN GET FLASH YOUR CELL PHONE.
DO LET ME KNOW WHICH GSM NETWORK YOU ARE USING AND YOUR CITY/AREA LOCATION.
Oct 22, 2008 | Nokia 6630 Cellular Phone
My V3 Razor won`t dial somtimes unless I power it off and on.
first u change your mobile software. I think after then your problem is 99% solved if problem present u change your network ic in your mobile mostley the problem is held for network ic when network ic disconnect from your mobile your mobile gave call failed in that case u r not recive any incoming call.u change your network ic your problem is solved.
May 16, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
82 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
