A4 paper seems to catch on left hand side,not feeding properly?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Perhaps..tried riffling it?
Posted on Aug 19, 2008
Paper feed jams on right hand side after I pulled bits of an A4 that came out ripped
Bruno:
You did not get all the pieces of that A4 paper out of the paper path. There is still a small shard of paper in the right side of the paper feed area. Use a flashlight to look carefully in the paper feed area and gently use tweezers to remove the piece of paper. If you pulled the sheet of A4 paper backwards out of the feed area, you may have dislodged the paper feed sensor (a small plastic finger that sticks down in the paper path to tell the printer that the paper has passed.) Be careful with the tweezers... if you break that sensor, there is no fixing it.
Jun 21, 2015 | Epson Stylus Photo R2400 InkJet Printer
MP150 paper feed not working on left hand side
Check your paper feeding roller, first clean them
Apr 30, 2012 | Canon PIXMA MP150 All-In-One InkJet...
Hi My epson rx620 keeps feeding paper on angle. when i take out paper there is a dent on the leading edge which seems to indicate an obstruction about 60mm from left hand side stopping left hand side of...
Top loading printers often get items falling into the paper feeder. Check for blockages and try using a vacuum cleaner hose with a narrow attachment to clean any rubish out.
Mar 16, 2011 | Office Equipment & Supplies
My paper seems to not want to feed properly it suddenly shifts to the side....Cannon ip3500
Make sure that the paper guide is up against the right hand side of the paper in the feed tray. You should not be adle to move the paper sideys in the feed tray. If you can, the guide is not set right.
Feb 11, 2011 | Office Equipment & Supplies
Machine does not "see" top tray with A4 paper. It seems to be expecting a side feed of paper. Prints on A3 if top drawer removed.
make sure the arm of the paper tray that runs from left to right is fully against the paper and that any keyway is correct take out the drawer turn it over and check nothing has come adrift
Jun 18, 2010 | Toshiba E-studio 281c Copier
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
Paper feed rolls is rolling over the paper...how to get access to those rolls
  1. Feed the paper manually into the printer:
    1. Place a sheet of plain A4 paper in the paper feed tray.
    2. Move the paper support on the left-hand side to the left end of the paper.
    3. Press the paper feed button.
    4. If the paper does not feed, continue with step 2.
  2. Check for any obstructions in the paper feed path:
    1. Disconnect the cables from the back of the printer.
    2. Open the front of the printer and check for anything that may be blocking the paper path.
    3. Close the front lid and remove any paper from the paper feed tray.
    4. Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
You can clean with special cleaning paper which ca be used clean the rollers............
Dec 08, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x3350
Nov 20, 2007 | Lexmark P4350 All-In-One InkJet Printer
64 people viewed this question
jasbo
jasbo
