Question about Dryers
Dryer not generating heat - Dryers
    Genius:
  • 2,920 Answers
Would indicate the heating elemeny is out or the limit switch has gone bad
Posted on Aug 19, 2008
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
Will not generate heat runs fine-it's only done about a 100 loads
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 01, 2011 | LG DLE1310 Electric Dryer
The dryer is on but very little heat is generated. The lint trap is clear and the botton is vacuumed.
heatman101
Nov 03, 2010 | Estate TGDS680EQ Dryer
Kenmore elite dryer is not generating heat to dry clothes. The machine is less than 4 years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 01, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer runs, but does not generate any heat. Is
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 31, 2010 | KitchenAid KEYS750LQ Electric Dryer
The dryer does not generate heat
its either the element or the sensor.
Nov 21, 2009 | Dryers
Dryer not generating heat and drying clothes...
Dear customer,
                We recommend you to do the following checks when your dryer isnt generating heat..
  1. Check for proper air flow
  2. Test the safety fuse
  3. Test the thermostats
  4. Test the centrifugal switch
  5. Test the timer motor
  6. Test the heating element.
Thank you.
May 09, 2009 | Whirlpool LEQ9858P Electric Dryer
My dryer does not not produce enough heat when in operation. It seems like it is just running and generating very low heat. Please help.
Really sounds like an element is burnt out or a safety has malfuctioned. Possible loss of power so check plug, recept., and breaker. Look for burnt terminals and reset breaker even if it does not look tripped. Dryer usually have 2 elements. One for low heat and both for hi heat. May want to check this out. Please keep in mind that some repairs can cost more than buying a new dryer. I got one at Lowes for about $200 and it works great. I don't think you can get a repair guy out and to the repairs for that amount. Just depends on how many whistles, buzzers, and bells you want on your machine.
Good Luck.
May 08, 2009 | Dryers
Dryer runs but will not generate any heat...
If not generating any heat then element is probably burned out- close visual inspection will general reveal break in element coils
If some heat then probably on of the thermostats gone bad. Will power off test for continuity with meter--if no reading replace
Good luck
Sep 05, 2008 | Frigidaire Dryers
Gas dryer/ whirlpool
well your generating heat which is a good sign, either there is a blockage in your venting() most likely source of issue!) but you say ou replaced, i would then look to replacing the valve coils, 279834, about 20 bucks, easy to replace... its possible that they open the valve upon start up allowing heat, but after being on 20-30 min they overheat and no longer open not allowing heat to generate..
Apr 03, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryers Logo
110 people viewed this question
Top Dryers Experts
