Question about Toshiba e-Studio 161 Copier Copier
Changing Developer on E-Studio 150
I have tried everything but i still dont know very well what is de developer (i had buy D-1200 is a bag with dust?) and what a most to do for change it. have you some picture of a developer recipient so a cant be sure that a im not making a mistake?
Thanks a lot for you atencion.
Angel Martin - Portugal
    Problem Solver:
  • 15 Answers
The developer you need to purchase is 1620 , and the drum unit also the 1620, you can see this number in the toner catridge itself. or in the toner catridge box. Regd. the 161 you need to purchase the products name 1620 number and the concerned part like developer, drum, toner, some gears etc.
Posted on Nov 19, 2008
SOURCE:
Como solucionar el c2557 de la konica minolta 282
When was the last time the the drum and developer was replaced in the developer unit? If has been replaced, then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier uses the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally, was the F8 run after the developer was installed before ant prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 28, 2017 | Konica Minolta Office Equipment & Supplies
Developer cyan c7000 spill
Yes you have to have the Cyan developer unit removed and have the developer changed. Once installed there are certain procedures to follow. If you don't follow the procedures you will be buying another bag of developer and start hole process over again
Sep 02, 2014 | Konica Minolta bizhub PRESS C7000 Cyan...
Where we can buy toshiba studio 230 developer?
677864645f7a396c54674d71464b78424b4677-100x100-0-0.jpg Toshiba E-STUDIO 163 202l Developer Black
New Genuine Original D2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $88.21ExtraMileToner
at
GenuineBrandSupplies.com
New Genuine Original D-2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $65.33
Oct 21, 2011 | Toshiba e-Studio163 Copier
What is the difference between the toner and developer on this printer? The manuals we have don't give any info on installing developer, but you can purchase both toner and developer for this...
Toner provides the color, Developer consists of magnetic particles that carry the color on the outside of the developer drum, which is magnetic. Some developer is lost on each copy, although most stays in the developer unit. When you run low on developer, your image gets lighter and lighter, until the machine reports an error because it can no longer self calibrate. One change of developer suffices for many changes of toner. There is a procedure involving various actions and codes to flush the developer material out and load new developer in. This is not difficult, but there are a couple of reasons you might not want to do it if you are unsure why or if you should. First, developer for these estudio copiers, is very expensive. Second, unless you know how many copies have been made on the existing developer, you might change the developer, and fail to correct the problem. There are related service items, involving the cleaning blades, and seals, servicing charging grids, corona wire, and general cleaning of the 4 developer units and opc drums. Including dusting with zinc sterate, etc., etc. Its hard to know where to begin or where to stop. If you really want to know all about it, order a manual from any of a variety of on-line sources. Good luck
Aug 30, 2010 | Toshiba E-Studio 310c Laser Printer
Sharp Copier AR-M355N developer change is after 100,000 copies. We were at 95,000 copies and copies were becoming light and the developer done to 1/4. We were told somebody dump the developer because it...
The developer stays in the machine in the developer unit. It is SUPPOSE to stay in the unit and the level doesn't go up or down. It just looses some of its magnetic property therefore needs to be changed. I have NO idea about dumping developer, if so...SOMEONE doesn't know what they are doing.
Sep 17, 2009 | Office Equipment & Supplies
First Installation
they are on the way plz dont forget to rate you expierience on fixya.com PLEASE LET ME KNOW IF NOT RECIEVED one was 20MB so it will take some time
May 01, 2009 | Ricoh Aficio MP1600SPF Copier
Developer leakage while copying
after replace  developer you dont turn round the developer wheel left side. only right side.try this take out the developer and after re fill in to the developer unit. and u change the main charger unit also.
Feb 06, 2009 | Toshiba e-Studio 161 Copier Copier
How do I change out the developer in my e-studio?
Send me an E-mail address I will copy and paste the instructions to you.
Jan 21, 2009 | Toshiba Estudio 200L Copier
Dialta di620, error codes c-0F34 AND C-OF33
Replace the developer if you can find it two bags are required. if that does not work mite be the sensors . when was last time a PM was done on the machine Drum replaced cleaning blade replaced? Remove the old developer then replace it then run F8 in service mode clear developer counter also.
Starter or Developer 8935-912 two bags
Drum 1155029101
cleaning blade 1074-090401
try percission roller company for the parts
Oct 16, 2008 | Minolta Office Equipment & Supplies
Changing the Developer on a Toshiba E-Studio28
If you are not a technician I would not even attempt this!
Jun 13, 2007 | Toshiba e-Studio 35 Copier
Toshiba e-Studio 161 Copier Copier Logo
157 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
