Question about Maytag 7.0 Cu. Ft. Electric Dryer
Overheating Dryer overheating....gets very hot on lower part of front of dryer below door. Have to turn on then off to cool. Don't think this is very safe. Have checked vent pipe.
  • jackglen Aug 19, 2008
    Can you remove the lint filter trap or the front of the dryer?
    If there is a charge or subscription for this service - just posting - please unsubscribe me. Was not aware of possible charges. Thank you.
  • 876 Answers
Do you empty the lint filter after each load? If you can take the dryer apart you may find that it has a lot of lint inside which you will carefully need to remove or vacuum out. Here is site that might be of some help to you with a diagram of a dryer. Be sure to disconnect the dryer from the power supply before you do anything to it. You are right, it is NOT safe and after you clean the lint out , you can at least see if that will help the dryer run cooler. (The back of a dryer sometimes comes off easily.) If it is not cooler after cleaning out the lint,not you need a repair man.
Sonetimes dryers overheat becasue the clothes we are putting in them are too wet. Is your washer adequately spinning the water out of your clothes?
I hope this helps you. Thank you for using Fix YA
Posted on Aug 19, 2008
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
Dryer shuts off after about 10 minutes. Motor feels hot, real hot. I think it is overheating and shutting off. The lower the setting the longer it will run. Is it the Thermal fuse or thermostat?
There might be a problem with the bushing of the dryer motor that causes the rotor to become shorted with the magnetic field and that's the reason why it becomes too hot. It is also the reason why the thermostat shuts off the motor when it becomes too hot to avoid overheating. Replace the bushing of your motor.
Nov 10, 2010 | Kenmore 63942 Dryer
Overheating dryer - motor replacement???
Good day,
You said "The dryer is still overheatng". If your not describing the motor but the whole machine then that problem will have to be resolved.
Maytag's build lint up badly in the blower housing area and the duct between it and the filter. Requires disassembling the front of the dryer and cleaning that area as well as determining if the blower wheel is loose on the motor shaft requiring replacing.
If the overheating is the motor itself, then replacing it would be a common item on that brand.
May 14, 2010 | Maytag Dryers
My electric dryer is becoming extremely hot during the drying cycle. I replaced a blown thermal fuse several weeks ago and the dryer was extremely hot at that time. The dryer runs but becomes so hot you...
Clothes will get very hot in the dry cycle, especially when the dryer is set to the warmest or hottest setting.
There are controls built into the unit to prevent it from overheating to the point of causing a fire. The thermal fuse you replaced is one of them (and I assume you replaced a perfectly good fuse with a new one as you said it was very hot.).
You might want to check the following if you feel the unit is getting too hot -
1) Make sure the lint screen is clean.
2) Make sure the hose between the back of the dryer and the exhaust duct at the wall wall is not kinked or full of lint.
3) Make sure the exhaust duct leading to outside of the house is clear and not full of lint.
Let me know what you find.
Dec 14, 2009 | Kenmore 62602 Electric Dryer
My old Hot Point Dryer would dry with hot air for about 2 loads (90 minutes) before shutting off in order to cool down -then it would dry again (about 3 hours later). Then the dryer just gave up the ghost...
A dryer motor has an internal thermal proctive device. It may have started out with a severe vent restriction which would not allow proper airflow through the dryer cabinet. A lint build up can result in the motor overheating as you described. The fact that nothing is happening at all would lead me to suspect one of the following. The motor failed completely, a thermal fuse opened, a circuit breaker triped or a fuse opened. Any one of these conditions would prevent dryer operation. But then, so would something as simple as a failed door switch. You may want to get a pro in to let you know what your options are......After you cycle your dryer circuit breaker, or check the fuses.
Nov 04, 2009 | Hotpoint Dryers
Dryer quit after about 20 minutes-see more details below
do you have clothes on top of dryer? if so, i'll say it again never ever stack clothes or anything on top of it. Things on it insulate it and will overheat the machine. Yes it has a overheat linit switch but to get to it you have to take it apart and pull the drum out depending on the style of heat element you have. Some are in the back of drum and others are in a tube on the floor of the unit inside. If yours is behind the drum then drum needs to come out to check for the problem
Feb 26, 2009 | Amana Dryers
Frigidaire dryer overheating
the other tstat is on front of blower housing..lift top remove screws at top of front panel from inside remove switch wires front lifts off ..be sure to ck vent first most dryers have thermal fuses that will blow if overheating does occur since yours seems to be working i would suspect vent first..if your concerned about dryer being hot to touch along top rear this is normal heating element is located just below console at rear
Nov 13, 2008 | Dryers
Dryer overheating
Friend,
ngfam1 At your service!
STOP DUE NOT RUN THE DRYER!!!!!!
FIRE HAZARD!
CALL SERVICE!!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Aug 30, 2008 | Dryers
Maytag 7.0 Cu. Ft. Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
