Question about Sony Cyber-shot DSC-W50 Digital Camera
No menu display when pressing menu button
Programm setting of my camera not work correctly
    Novelist:
  • 208 Answers
START SIMPLE, ARE THE BATTERIES FRESH? WAS THE CAMERA WORKING BEFORE THIS ERROR? HAVE YOU DONE A POWER UP, POWER DOWN RESET MODE? DID THAT DO ANYTHING? DID THE CAMERA SIT FOR A LONG TIME IDLE WITH THE BATTERIES IN IT? DO ANY OTHER FUNCTIONS WORK? I HATE TO ASK SO MANY QUESTIONS BUT I NEED A BASE TO DETERMINE WHAT CAUSED THIS LAPSE. ANY PHYSICAL DAMAGE TO CAMERA? ANY HEAT/COLD EXTREMES? MOISTURE? FOR NOW I NEED INFO, I WON'T ABANDON YOU IN MIDSTREAM, JUST GET ME SOME INFO AND I WILL CONTINUE ON FROM THAT POINT! THANKS! REPLY TO:
ARCLIGHT1217
Posted on Nov 07, 2008
I'm trying to set th time and date on my camera but when I hit the menu button the yellow lock appears how can I get rid of this so I can set time and date correctly please
Hi Keith, The link below is the user manual for the Pentax Optio E30 Digital Camera, On page 56 it says
• In Green Mode, you cannot change the information displayed on the LCD monitor by pressing the 4/W button.
• You cannot use the [A Rec. Mode] menu or Capture Mode Palette in Green Mode. If you try to display the [A Rec. Mode] menu or Capture Mode Palette, - (key lock icon) appears.
• If you switched to Q mode from Green Mode, you cannot display the [H Setting] menu by pressing the 3 button. If you try to display the [H Setting] menu, - (key lock icon) appears.
• When the camera is turned off in the Green Mode, it turns on in the Green Mode next time the power switch is pressed.
THIS IS YOUR CAMERAS USER MANUAL.....CHEERS..
http://www.camera-usermanual.com/manuals/pentax/Pentax_Optio_E30.pdf
Mar 27, 2016 | Pentax Optio E30 Digital Camera
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
How do you set the clock
Hello
To set the clock to your SV-dvd 3E:
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Oct 10, 2011 | Samsung SV-DVD3E DVD Player/VCR
Were is the reset button
Hi plozgangster ,
DSCW370 Digital Camera do not have a physical reset button. What you can do is to initialize the settings of the camera. This works the same as pressing the reset button. You may follow these steps:
  1. Press the Menu button to display the MENU screen
  2. On the Menu screen select SETTINGS using the up or down arrow, then press the middle button to display the SETUP screen.
  3. On the SETUP screen, use the arrow keys to go to Main Settings.
  4. Look for INITIALIZE then select it using the middle button
For camera hand out please click on this link
Jun 13, 2011 | Sony Cybershot DSCW370 Digital Camera
How do I set the time and date on a Panasonic DMC-LZ4
1. Press the menu/set button. This will bring up a menu.
2. Press arrow left (the button left of the menu/set button).
3. Press arrow down (the button below the menu/set button). This will select the setup menu (so, a wrench icon should be brighter than an icon of a camera).
4. Press arrow up or down (these buttons are above and below the menu/set button respectively) to highlight clock set.
5. When clock set is highlighted press the right arrow button (button right of the menu/set button).
6. Press right or left to select what settings you want to change.
7. Press up or down to get numbers according as you want them.
8. Repeat 6. and 7. as desired.
9. Press menu/set several times to exit menu options.
Feb 28, 2011 | Panasonic Lumix DMC-LS80 Digital Camera
Cannot set the Time/Date
Setting the Date and Time The date/time needs to be set if/when: Camera is turned on for the first time. Camera is turned on after leaving ViviCam X60 without the battery for an extended period of time. When the date and time information is not displayed on the LCD monitor, follow these steps to set the correct date and time. 1. Slide the mode switch to [replay ], and press the MENU button. 2. Select [Setup2] with the LEFT ARROW button. 3. Select [Date/Time] with the UP ARROW / DOWN ARROW buttons, and press the SET button. The Date/Time setting screen will be displayed:[Setup] [Format], [On/Off]. 4. Select [Setup] with UP ARROW / DOWN ARROW buttons,and press the SET button. Select the item’s field with theLEFT ARROW / RIGHT ARROW buttons and adjust the value for the date and time with the UP ARROW / DOWN ARROW buttons. The date and time is displayed as the format you set. The time is displayed in 24-hour format. After confirming all settings are correct, press the SET button. The setting will be stored and the screen will return to the Setup2 menu.
Jul 05, 2008 | Cameras
From chinese to english
Right from Cannon:
Issue:
How do I set the language?
Solution: Procedure for setting the language PowerShot S5 IS.
Setting the Language
The language in which menus and messages are displayed can be selected with this function.
Method 1
  1. Power the camera on in the playbackicon.gif (Playback) mode.
  2. Hold down the <SET> button and at the same time press the <MENU> button.
  3. Use the direction_arrow_up.gif, direction_arrow_down.gif, direction_arrow_lt.gif, or direction_arrow_rt.gif button to select a language and press the <SET> button.
Method 2
  1. In the playbackicon.gif (Playback) mode press the <ON/OFF> button until the power lamp lights.
  2. Press the <MENU.> button to display the Rec. or Play menu.
    - Use the 023.gifbutton to select the setup_icon.gif(Set up) menu.
    - Use the 021.gifor 026.gif button to select LANGUAGE and press the <SET> button.
  3. Use the 021.gif , 026.gif, 023.gifor 028.gifbutton to select a language.
  4. Press the <SET> button.
  5. Press the <MENU> button to redisplay the Rec. or Play screen.
Oct 12, 2007 | Canon PowerShot S5 IS Digital Camera
Redeye
Red-eye is actually caused by the light from the flash bouncing off the back of the retina and picking up the color red from the blood vessels. To correct this effect, follow these steps: Turn the mode dial to PlayBack Mode (green arrow) and display the image with redeye. Press OK\Menu button. Using the arrow pad, navigate to MODE MENU>EDIT>REDEYE FIX. Press the right arrow key, START will display. Press OK\Menu After {BUSY} bar displays, a screen will display with an option to cancel or save the image. ? If the option [Go] is displayed, press the OK\Menu button. This saves a corrected version of the image. ? If the option CANCEL is displayed, than the camera was unable to correct the image. Press the left arrow key to exit. This correction may not work on all pictures. If you import the original image into Olympus Master software you can also apply the Red-Eye fix located in the Edit menu. This lets you precisely pinpoint the eye area and remove the red. It even lets you remove green or blue, which can occur with animals.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Redeye
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Sony Cyber-shot DSC-W50 Digital Camera Logo
29 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
