Aoc L32W781A LCD tv the colour seems to flicker randomly mainly on bright colours and bleed on picture any ideas?
Slinteriors
  • 8617 Answers
SOURCE: colour issues
Sounds like your red gun may be shorted, Try adjusting the red gun down a little see it that helps.You can also switch the blur CRT socket for the red if your screen is still mostly pink then you know for sure its your red tube that needs replacement. If its mostly blue then you have a problem in the red drive circuit.
Posted on Jan 14, 2008
SOURCE: Ghosting on LCD TV
get a big heavy brick and throw it at the screen this fixed mine
in no time and got a sony instead
Posted on May 29, 2008
SOURCE: Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Posted on Jun 08, 2008
  • 1011 Answers
SOURCE: I am unable to get
dear,
check the correct connection of AV cable..
or maybe its defective..try with another one..
regards,
Posted on Aug 17, 2008
  • 17 Answers
SOURCE: problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Posted on Aug 31, 2009
Voxson 40inch LCD TV model VLCD40cp 2yr old turned on & ok for about 20 mins then bright green flickers , were black colour should be! Fixable? Cheap or dear?
Overloaded picture. The main board is likely to be faulty. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 30, 2016 | Televison & Video
Tv screen flickering,picture,colour and sound perfect
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 13, 2015 | Televison & Video
How to fix aoc l32w751a tv vertical random coloured lines at power on, won't respond to remote
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 07, 2014 | AOC Televison & Video
How to fix AOC LCD TV random vertical coloured lines, no response to controls
Sounds like a screen fault. The adhesive that attaches ribbon cables from the drive electronics to the screen has failed. Unfortnately this isn't fixable because the connection and spacing is too fine to get a 100% reliable connection. Some DIYers have used neoprene rubber tubing as wedges to hold the connections in place. That actually works. Search Youtube
Random Side Panel Inputs
You either have a bad Main board or simply a bad touch control button in other word one of your side buttons is defective and it is blocking any other signal to the main board, but usually its a bad main board. In some cases ther is a FIRMWARE update from Panasonic, you may want to call Panasonic or check there website for any type of FIRMWArE UPDATE.
May 10, 2014 | Panasonic TH Televison & Video
I find the colour contrast is very dark could you send me ideal colour settings for perfect clarity thanks
Hello
Adjust the contrast to 55 to 70%; brightness to 45 to 55% and colour to your viewing taste. Now the brightness will be very low I thinks. Advance the brightness and contrast after setiing the colour to Zero. Adjust for a well defined B/W picture first. The advance the coulour. Take reference of the face colour of a news reader at studio. The picture will be perfect. OK.
Jul 07, 2011 | LG 42LB1D 42 in. HD-Ready LCD TV
Samsung 40" LCD LE40R74BDX screen flickering all different colour
You either have bad Main bd and or a bad T-Con bd on the Panel. Have a trained samsung tech troubleshoot the set.
Jun 30, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Aug 21, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Red screens cause flickering
if normal tv is fine then ,likely the signal from the box is too hot.
if using composite switch to cable ch 3 or vice versa,
or use hdmi cable or change the box .
Apr 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
